Thread: car wont start
    Member barryTA's Avatar
    Aug 2006
    ARIZONA
    2001 trans am
    car wont start
    my car wont start the security light is flashing the starter is not clicking wtf!!
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    search for vats or pass-II bypass
    Senior Member
    Jacksonville, FL
    If it's not turning over at all and security light on the IPC is flashing sounds like a VATS issue - car isn't recognizing the resistance value in the key. First thing I'd do is try another key, or clean the pelet on the one you're using. If it is VATS sometimes it'll start normally after a few minutes and the security light goes off, depends on if it failed while the car was running or not. If it turns out to be the key cyl itself you can try a VATS bypass with a resistor that matches your key until you get it fixed. Lots of info here if you search for VATS.
    Aug 2006
    ARIZONA
    2001 trans am
    Thanks Guys Looking In To It.
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 08:54 PM
  2. Z71 wont start
    By duranws6 in forum General Help
    Last Post: 01-09-2013, 07:49 PM
  3. LT1 wont start
    By Bad Co. in forum General Help
    Last Post: 11-18-2010, 07:23 AM
  4. LT1 wont start
    By Bad Co. in forum LT1
    Last Post: 11-16-2010, 05:32 PM
  5. car wont start
    By redss2000 in forum General Help
    Last Post: 06-20-2008, 01:06 PM
