Results 1 to 2 of 2
Thread: piston ring question
05-27-2007, 09:55 PM #1Junior Member
- Oct 2006
- California
blue- 2002 2500HD
If I have already broke in my motor and need to pull the piston out is it important to put the piston back in with the rings in the excact location that they were initially put in? I have read that rings will rotate so it is not important but others say that it is.
05-28-2007, 06:15 AM #2
really doesn't matter. just make sure the top and second ring gap are 180* apart from each other.
piston ring placement??
By glamisbound in forum Internal EngineReplies: 4Last Post: 01-06-2014, 05:53 PM -
LQ9 piston ring gap
By tylerdurden1 in forum NitrousReplies: 6Last Post: 01-15-2008, 10:00 PM -
piston ring side clearance
By white99SS in forum Internal EngineReplies: 4Last Post: 05-07-2007, 12:43 PM -
piston slap question
By slpws6ta in forum Internal EngineReplies: 7Last Post: 01-01-2007, 04:32 PM -
6.0L Build Piston/Rod Question
By HotRodV6 in forum Internal EngineReplies: 1Last Post: 11-07-2005, 11:16 AM
