Results 1 to 2 of 2
    Sonoma GT w/416 L92/T56 HotRodV6's Avatar
    Humble Tx 77396
    1992 GMC Sonoma GT
    Question 6.0L Build Piston/Rod Question
    Ok, well im building a 6.0L for my Sonoma GT and while i want to builkd a stroker, the money for the crank and just not there right now, so i am going to use the stock 6.0L crank, and i wanted to know if you can run a 6.125 rod on the stock crank and what pistons would be needed to get atleast 10.75 -11.0 CR and i have a set of stage one ported LS6 heads with 2.02 1.60 valves that flow right around 280 on the intake side and 180 or so on the exhaust side.
    Is there a shelf piston that i can use or would i have to go custom. I know once i get the stroker crank ill need new pistons, so i dont really want to drop alot on pistons right now, even a Hyperutectic set would suffice.
    Thanks for the help.
    Humble Tx 77396
    1992 GMC Sonoma GT
    Anybody??
    1992 GMC Sonoma GT #492 of 806 built.
    Under Full Resto w/433 E85 L92/4L80E.
    1992 GMC Typhoon #1104 of 2200 built.
    Broken Crankshaft. New Engine Soon.
    2000 Olds Bravada
    Bagged 2wd Frame Swap
    L31 swap Planned
    Daily Driver
  1. Help: build question
    By knightshade0 in forum LS2/LS3/LS4/LSx
    Last Post: 08-22-2016, 11:23 AM
  2. Another head/cam build question
    By 02ssmaro in forum Internal Engine
    Last Post: 03-20-2011, 09:47 PM
  3. Caliper question (Fluid in piston boot)?
    By nyarsulik in forum General Help
    Last Post: 09-05-2009, 03:35 AM
  4. piston ring question
    By john1l40 in forum Internal Engine
    Last Post: 05-28-2007, 06:15 AM
  5. piston slap question
    By slpws6ta in forum Internal Engine
    Last Post: 01-01-2007, 04:32 PM
