Thread: piston slap question
12-31-2006, 11:38 AM #1
I have a 2000 ws6 m6 with 75k on it i am in the process of rebuilding the engine because the piston slap ( or what i belive to be piston slap) has become unbearable. i will know soon enough what the noise is for sure but is there anything i can do, short of a resleeve and pistons, to get rid of it if it is piston slap. I am an auto tech and i do all my own work but i work for toyota usually if i get a car with piston slap I pull the head and the cross hatch is worn out of the cyliders at which time it gets a short block. I'm going to be ordering a cam kit, clutch, flywheel, 4.10 gears and such but if i cant get rid of the piston slap I want to know so i can order a bare block. Any input from any one who has been through this would be greatly appreciated thanks
12-31-2006, 11:53 AM #2
seems it does not hurt the LS1 motor so no one tries to correct it, do a search.
12-31-2006, 02:35 PM #3
i have done extensive research and motors with piston slap have short "life expectancy
12-31-2006, 02:36 PM #4
shorter not short
01-01-2007, 05:47 AM #5Junior Member
- Dec 2006
- Minneapolis
Pewter- 00 Camaro SS
It is my understanding that piston slap was due to the short skirts of the pistons and weak rings. Replace the pistons and your motor will quit slapping.
01-01-2007, 01:31 PM #6Junior Member
- Dec 2006
- Minneapolis
That's what I meant
01-01-2007, 01:58 PM #7Member
- Oct 2005
- RI
Mag Red- 2002 Vette
There was a piston update in the spring of 01, which included coated pistons. Are you using these in the rebuild? If you have it down that far, have you considered a forged bottom end? Might not get rid of the slap (forged pistons require a bit more cold clearance) but it would be a lot stronger.
01-01-2007, 04:32 PM #8
piston slap or not
By acews6 in forum General HelpReplies: 2Last Post: 11-05-2014, 10:07 AM -
Piston Slap + Cam = ?
By WS6ICK2K in forum Internal EngineReplies: 0Last Post: 05-05-2008, 07:14 PM -
Piston Slap
By shlby123 in forum General HelpReplies: 10Last Post: 01-18-2007, 01:39 PM -
piston slap?
By wicked illusions in forum Camaro / SSReplies: 4Last Post: 05-28-2006, 05:27 PM -
Piston Slap
By CamaroSSx1999 in forum Internal EngineReplies: 6Last Post: 08-29-2005, 01:43 PM
