Thread: Piston Slap
08-27-2005, 12:17 PM #1CamaroSSx1999Guest
Piston Slap
what is it????
08-28-2005, 05:07 PM #2DougLs1Guest
Its when there is slop (too much space) between the piston and the cyl wall.
08-28-2005, 07:09 PM #3I like the way yew tawlk.
- Blairsville, GA
Red- 2000 T/A WS6
It sounds like a diesel engine, usually around 2500 rpm. Some LS1s have it, some don't. GM says it doesn't affect performance, apparently.
08-28-2005, 08:50 PM #4CamaroSSx1999Guest
will it mess ur car up? b/c i have it at idle if i rev to 1k and when it drops down it does it... is my motor gonna blow up of something one day?
08-28-2005, 11:47 PM #5CamaroSSx1999Guest
well i never had it until i switched to moible,... u think i should switch back? i need good advice... because its kind of bad ... just when the idles droppin
08-29-2005, 04:41 AM #6I like the way yew tawlk.
- Blairsville, GA
Red- 2000 T/A WS6
Are you runnin 5W30? A higher viscosity oil will at least reduce slap, but I wouldn't do 20W50 if I were you. Try 10W30 or 10W40... hell, see what Rotella T 15W40(diesel engine oil) does in it.
08-29-2005, 01:43 PM #7CamaroSSx1999Guest
i mixed 10-30w moibleone full syn. w/ lucas oil stabilizer... thinking about putting alittle seafoam in to keep pcv clean. duno... new oil and stabilizer helped. never had this prob. with non syn. might switch back if it doesnt get better. but i was told full syn. is the best thing for the ls1.
Piston Slap?
By 1999sscamaro in forum Internal EngineReplies: 16Last Post: 10-31-2025, 05:43 AM -
Piston Slap + Cam = ?
By WS6ICK2K in forum Internal EngineReplies: 0Last Post: 05-05-2008, 07:14 PM -
Piston slap or not???
By casperss in forum Internal EngineReplies: 6Last Post: 09-21-2007, 07:06 PM -
Do You Have Piston Slap?
By A~NICE~CAR~IS~A~NICE~CAR in forum General HelpReplies: 12Last Post: 11-16-2006, 06:30 AM -
piston slap?
By wicked illusions in forum Camaro / SSReplies: 4Last Post: 05-28-2006, 05:27 PM
