Results 1 to 17 of 17
Thread: Piston Slap?
    Junior Member 1999sscamaro's Avatar
    Jul 2010
    st louis mo
    1999 ss camaro
    Piston Slap?
    Hey, i have had my 99 camaro for about 7 months now and i first got it during the summer. my issue is that during the summer you could here a little knock when the engine was cold but when it warmed up it went away. when the winter hit you can hear it more now but it isnt that bad but it still some what concerns me. i know the early ls1's had piston slap issues espically the 97 years but im just curious if any one else has the same problem? during late or mid summer i plan on tearing down the block and building a engine but im just worried about it now so i dont really need it to last another year just about another 6 months.
    Member youngrigo's Avatar
    Nov 2010
    Bay Area, CA
    2000 SS
    Run a little thicker oil
    Jul 2010
    st louis mo
    1999 ss camaro
    thats what im running now, i changed the oil right before winter. the knock doesn't happen every start up either, just at certain times.
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    they all slap lol ive ridden in every year ls1 except a 97 and with the exception of a 98 ls1 they all slapped particularly the 01-02 did it worse. In 01 gm switched piston rings and teflon coated the piston skirts which may have added to the problem. as long as its not burning a crapload of oil i say run her hard
    Mar 2010
    sac
    piston slap will not go away, it is MOST likely your lifters, does it sound like a diesel when it first starts. try strait 30weigt.
    do a compression test
    Jul 2010
    st louis mo
    1999 ss camaro
    Yeah i realize alot of them have them im just curious if it causes problems. It hasnt had any problems and i drive it like a bat at of hell some days but i was just curious.
    im almost 100 percent sure its not lifters or any other knock but you are right i should do a compression test which i might do when spring hits
    As stated the LS-1 is known for cold start piston slap. It is the combination of short skirt pistons and material expansion rates that causes this. Generally, it is nothing to be concerned with and you need not take any special measures. When we first purchased our car back in 2008, my friends were a bit alarmed by the way the engine sounded at startup. Like me, they were all old school and to have an engine sound like that was a bad thing. However, once it gets a little heat in the engine, things quiet right down. I would not worry about it -- for peace of mind, there are lots of guys on here that have rolled well in excess of 150,000 miles on their cars with no internal engine issues.
    Jul 2010
    st louis mo
    1999 ss camaro
    thanks that puts peace of mind and yeah it stops once it gets heated up. i have about 126k on mine with no engine issues and it still runs like new only problem has been with the tranny and rear end like most f bodies.
    The Demon Demon_Z28's Avatar
    Feb 2008
    WA
    Bright Rally Red
    My 98 Camaro had no piston slap, my 01 has it... It truly will never 100% go away, but the noise goes down when it is warm. Having an exhaust cut out also makes it quieter lol.
    Mar 2009
    ya what he said lol i did the lifters on mine and nothing changed fwiw, mine does it bad and it runs hard just put a bolt on g35 coupe in its place last night so shes still running strong at 118k
    Junior Member whitetrashbird's Avatar
    Dec 2010
    Tx
    Blue
    02 Firebird Transam
    As already stated, it appears to be pretty common in these engines. Mine has it when I first start it in the cold and goes away after I warm it up. No problems so far, I just take it easy on it (a good idea with any engine) until it warms up.
    Dan
    "Timid men prefer the calm of despotism to the tempestuous sea of liberty"....Thomas Jefferson
    Retired Outlaw Sum Bitch
    Your choice of oil filter will have a larger effect on piston slap than going up a grade of viscosity. Go back to a 30 weight and try a WIX or NAPA filter. What filter do you have on there now?
    Junior Member Mystic Z-28's Avatar
    Dec 2010
    NE
    Mystic Teal Metallic
    Piston slap is just more annoying than anything. It won't hurt anything. My car has it and it takes a good 15 minutes after start up to go away completely. Summertime it only takes about 5 minutes or less though, to go away. Like what was said above, go easy on it until she's fully warm.
    Piston slap does nothing to harm your motor... it is just annoying to some.
    Only two things I have found that "helps" or "reduces" it are these.
    (Keep a 30 weight oil in there. DO NOT think for one second a heavier weight oil is doing anything to reduce piston slap. HT/HS is just fine in a 30 weight.)
    1. Use a High Flow Oil Filter. Wix/Fram XG/Mobil1
    2. Use the TCW3 in your fuel. It washes the cylinders and we have quieted a lot of LSX motors with this easy/cheap to use fuel add.
    + 1 on the TC-W3. We run it in all our vehicles every fill up.
    I have no "scientific data" on TCW3 and how it quites the motor.
    My theory is fairly simple....I see it cleaning the ring packs and washing the cylinder allowing better oil film "stregth"......thus a quieter motor.
    Oct 2025
    london
    bmw s3
  1. Piston Slap + Cam = ?
    By WS6ICK2K in forum Internal Engine
    Last Post: 05-05-2008, 07:14 PM
  2. Piston slap or not???
    By casperss in forum Internal Engine
    Last Post: 09-21-2007, 07:06 PM
  3. Do You Have Piston Slap?
    By A~NICE~CAR~IS~A~NICE~CAR in forum General Help
    Last Post: 11-16-2006, 06:30 AM
  4. piston slap?
    By wicked illusions in forum Camaro / SS
    Last Post: 05-28-2006, 05:27 PM
  5. Piston Slap
    By CamaroSSx1999 in forum Internal Engine
    Last Post: 08-29-2005, 01:43 PM
