Thread: LQ9 piston ring gap
01-13-2008, 09:38 AM #1Junior Member
- Dec 2007
- Austin, TX
Pewter- 2002 Trans am WS6 T-top
LQ9 piston ring gap
I have been searching this forum and ls1tech with no results. If I have a balanced and honed LQ9 6.0L; What type of pistons rings (brand w/ part #) will work with the coated oem pistons?
What is the coating on the piston (telfon or cermic)? Will it effect the heat generated by N2O?
01-13-2008, 12:00 PM #2
Call Total Seal on Mon. and they will make your rings specifically to your app.
We use the Advanced Profiling ring alot. It is a very strong ring and has lasted a couple seasons on many of our customers bracket motors. ANYONE that has had to file a some of these bad boys will tell you. It takes me 3 times as long to file a set of these than regular moly file fits.
The biggest thing with the nitrous and your ring pack is the gap. All that added cylinder pressure makes the rings butt together and break or ring failure will be the end result.
They will need your exact hone size on the cylinders. It will save you a lot of time or who ever does the file fitting.
Back in the day I thought they were a waste of money. I NOW KNOW BETTER! ANYTHING I plan on blowing the bottle through I put there rings now. Some of my customers have bought the HellFire rings which are a gap-less design also just from another company and seen gains.
http://www.totalseal.com/
Thats my 2 cents for you.
What your installing your oil rings it was found out by a Nascar engine builder (that orders all rings from Total Seal) the rings build more power when the oil rings are installed tee pee up. Squeeze the oil ring together and which ever ring goes up like a tee pee place that up on the piston.
01-14-2008, 04:29 AM #3
when i did my 408, i talked with wiseco pistons.
top ring was set to .0055" per 1" bore
second ring was set to .005" per 1" of bore
4.030" x .0055" = .022" gap top ring
4.030 x .005 = .020" gap second ring
best to talk with your piston manufacturer to make sure.
as far as the coatings go. the top is a ceramic. the sides are a teflon.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
01-14-2008, 07:29 AM #4Junior Member
- Dec 2007
- Austin, TX
Thanks for the input guys. Iam going to be droping off this block in a couple weeks to a machine shop. I will have it torque plate honed, and then make sure all the cylinders are even. That measurment will be given to Total Seal before ordering.
01-14-2008, 07:53 AM #5
So it will be square decked then....? I think that's what you were saying. If not have that done. Also did you buy head gaskets yet? If not I would STRONGLY recommend you buying a set of Cometics or the Fel-Pro MLS. Make sure you tell the machine shop you plan on using that type of multi layer head gasket. They require a little bit different deck surface to get max. sealing. There is a word and measurement for that but it's too early for me to remember right now.
01-14-2008, 09:09 AM #6
15 RMS is usually what you want for the deck surface and using MLS gaskets.
01-15-2008, 10:00 PM #7Junior Member
- Dec 2007
- Austin, TX
Ls2tuner I wanted to make sure that the cylinders were close to +or -.001 of each if possible and have the block squared and deck. I was already leaning towards Cometics .040.
Thanks, mrr23 for the RMS number. I now have something to go by when filling out the order.
piston ring placement??
By glamisbound in forum Internal EngineReplies: 4Last Post: 01-06-2014, 05:53 PM -
piston rings on a 98 ls1
By Leeroyws6 in forum General HelpReplies: 1Last Post: 05-19-2010, 05:04 AM -
piston ring question
By john1l40 in forum Internal EngineReplies: 1Last Post: 05-28-2007, 06:15 AM -
piston ring side clearance
By white99SS in forum Internal EngineReplies: 4Last Post: 05-07-2007, 12:43 PM -
5.3L Piston?
By 99transamC/FIA in forum Internal EngineReplies: 0Last Post: 06-30-2006, 10:02 AM
