    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    broken header bolt
    buddy of mine has a gmc truck with the 6.0L in it....he was towing his trailer up some steep hills and heard a funny noise all of a sudden.....pulled the truck over..popped the hood....and noticed he broke the head off a header bolt....he was like wtf? as his truck is 100 percent stock...first how could this happen? overtourqed from the factory? truck is a 2002 i think...67k miles...second.....how is he gonnna get the broken stud out to replace it?? take the head off the side of the block and drill it out???? thanks
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    if only the head of the bolt broke off, there will still be the stud part of it. remove the exhaust manifold and put a pair of vice grips on the remaining part of the bolt and turn it out.
    Senior Member
    rochester,ny
    pewter
    thats what i was thinking as well but u think it would be possible to get a good enough grip with vise grips???
    S. Florida
    98 Formula /93 Z28
    Quote Originally Posted by tonyjnjz View Post
    Most likely.
  1. Broken Bolt
    By johnfin in forum Firebird / WS6
    Last Post: 09-07-2012, 03:33 PM
  2. Broken header/head bolt.
    By 98maro in forum General Help
    Last Post: 01-14-2011, 11:12 PM
  3. Broken Header Bolt?
    By etownfbplayer in forum External Engine
    Last Post: 05-09-2010, 07:24 AM
  4. Broken Bolt
    By bealschad in forum Internal Engine
    Last Post: 02-22-2007, 02:48 PM
  5. Broken rocker bolt, what to do?
    By andrewdruiz in forum Internal Engine
    Last Post: 07-18-2006, 04:20 PM
