Results 1 to 15 of 15
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    Broken header/head bolt.
    Hey guys...
    Today I too my car to the shop to install the electric cutout, so I ask the mechanic how much he would chrage me to install the LTs.
    So he was taking a look at the car when it was on the lift. And we noticed the bolt on the passenger side manifold wasn't there. Is the one close to the fire wall.
    Could that be a problem? Car runs good. Sometimes I can hear exhaust leak. Idk if cuz of that.
    How could fix this problem?
    And 2nd problem. The oil pan gasket is leaking oil
    Thanks for the help
    02 tahoe Z71 blacked out
    98 z28 red m6 sold
    07 zx6r ninja flat/black sold
    08 zx6r ninja sold
    NC
    1998Z28
    They make extractors for broken bolts. My set came from Sears. If the bolts broken off to where you can't get ahold of it then your ready for some fun. You basically drill a hole in the center of your bolt then use the extractor tool to back it out. Use plenty of whatever kind of penetrating oil spray you can pickup at your local auto parts store cause if you break the extractor off in the bolt your screwed.
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    What PFM said. If that happens, be prepared to remove that head for more drilling.
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Are you sure it's broken and didn't just back out? I didn't see in your post where you found it to be broken, only missing. Sorry if I read incorrectly. I have had several back out on me, even with the stage 8's I bought...although I have aftermarket headers, and from what I understand yours is stock?
    actually the oil pan gasket is a bigger headache than the bolt.....are you sure it's the oil pan and not the rear main? Where was the oil at?
    Feb 2010
    Damnso I'm sure Is a pain in the butt...
    The bolt is not there. The mechanic checked it to make sure. It can't really tell if it's broken or missing. But the guy I bought it from said nothing was done to the engine before.
    It has the stock manifold.
    Can It jst get broken by it self,?
    Most of the bolts are rusty
    Quote Originally Posted by 98maro View Post
    it probably just backed out and fell out
    Probe the bolt hole with a paperclip or something and see how deep it is.
    ^^^^what he said. I would worry about the header bolt later. Oil leaks need to be taken care of stat
    Sent from my iPhone
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Yes these exhaust manifold bolts break by themselves ALL the time. We do them somewhat frequently on Escalades and Hummer H2s. In fact I just did 3 on one Escalade 2 days ago. 2 of the bolts had a little bit of the remaining bolt stick out after the manifold was removed. That makes it a little easier to grab on to and back it out. The other one was broke off even with the head. I had one of the body shop guys come down and weld a nut to the bolt so we could back it out. It took 6 tries but finally the nut stuck to the bolt good enough to back it out.
    Feb 2010
    I noticed the oil leak when the car was on the lift. It doesn't leak alot. But I can see it there.
    The pan bolts have oil. And I can see more leak between the trans and the engine. Is an m6
    It seems to be hard to replace it. The mechanic said it was the gasket.
    Car has 124xxx miles.
    I'll try and stick something on the hole and see how deep it goes in.
    It doesn't have enough room is gonna take me a while.
    That seems hard to do too.
    Pull the coil packs and you'll have a lot more working room from the top. Other option is from underneath -- that's how I get at the back passenger side plug. The broken/missing bolt may also be more easily accessible from underneath as well.
    Feb 2010
    Thanks jeff.
    I would do that as soon as I have a chance.
    I'm planning on doin heads and LTs.
    What could happen if I keep driving the car with the missing bolt?
    Thanks jeff.
    You will probably have an exhaust leak that will sound like a ticking noise. If it gets real bad, outside air can be drawn into the exhaust and that will mess with your O2 sensor on that bank. Unfortunately, fixing it would probably require removal of the head. I just don't think there is enough room back there to drill it. Even if you could get an angle drill up in there, no way to keep the drill bit going centered and straight.
    Feb 2010
    i has an exhaust leak,,now that i pay atention to it.. it does make a noise... there is no room to work on it... ill just wait till i get new heads and headers
  1. Help: Broken intake bolt in head. HELP!
    By BLK2KSS in forum External Engine
    Last Post: 07-22-2011, 12:47 PM
  2. Help: Broken intake bolt in head. HELP!
    By BLK2KSS in forum General Help
    Last Post: 07-22-2011, 11:22 AM
  3. Easiest way to remove a broken bolt in the head?
    By Lunatikgixxer in forum General Help
    Last Post: 04-30-2011, 08:12 AM
  4. Broken Header Bolt?
    By etownfbplayer in forum External Engine
    Last Post: 05-09-2010, 07:24 AM
  5. broken header bolt
    By tonyjnjz in forum External Engine
    Last Post: 04-30-2007, 03:16 PM
