07-20-2011, 07:33 PM #1BANGIN GEARS>STAB N STEER
- Nov 2009
- Jacksonville FL
TRIPLE BLACK- 2000 CAMARO SS M6 #2100
Broken intake bolt in head. HELP!
Ok, so I’m pretty much an idiot and after telling myself numerous time not to over tighten the intake manifold bolts I did just that and snapped the third from front to back on the passenger side. It is barely flush with the surface if not below so the old welding a nut or wrench is a no go unfortunately. Is this going to be possible to get out without removing the head? Any help on this will be greatly appreciated. Thanks guys.
-Jason
07-21-2011, 04:43 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Depending on how easy it is to get to, you may be able to drill it out and use an easy out. Or drill and re-tap the hole. Just be careful and make sure you drill straight, if you do attempt it. I would try the easy out first, as you won't need to drill through the entire bolt.
07-21-2011, 01:35 PM #3
Wow post #666 talk about a bad omen
Maybe you can get some needle nose vice grips on it if you open up the area at the top of the hole a little.
Make sure you cover the intake ports on the head if you drill or dremel it.
Then run a thread chaser down after you remove the stuck bolt to make sure the next bolt goes in nice.
Then vacuum real good after you finnish.2010 Camaro SIM 2SS/RS A6
1999 TA A4 NBM
12.265 at 110.52mph
07-21-2011, 02:15 PM #4
If the face is fairly flat, I would carefully center punch it and then drill it with a small sharp bit -- maybe 1/32" or smaller in size to start. As posted, tape off everything real good so you don't drop chips into the engine. There should not be a great amount of pressure on the threads, unless you somehow managed to bottom out the bolt in the hole -- which I doubt would happen. Step up your drill bit size a little at a time and then use an easy out, or even a left hand drill bit, and it should walk up out of the hole as long as the threads are in good shape.
I have found that if the center punch is not right on the money, you can use a popsicle stick or other small piece of wood to gently push the drill bit in the direction you need to go as you start to drill. Stay as straight to the bolt hole as possible -- sometimes having someone watching the drill angle from a different perspective can help you stay on path. Good luck!
07-22-2011, 01:45 AM #5BANGIN GEARS>STAB N STEER
- Nov 2009
- Jacksonville FL
Thanks for the help guys! I actually ended up getting it out without using an easy out. I let it soak in wd-40 over night and most of the day and when I was trying to punch it to start the drilling/easy out process I noticed that it slightly moved (rotated). After seeing this I realized that it wasn’t bottomed out and was basically moving freely within the head and the wd-40 made it pretty lubricated so I took the smallest flat head screwdriver I had and patiently tapped it over and over again, it took over an hour, until I got it enough above the surface to get a good grip on it with some pliers and got the sucker out. I was pretty excited when it came out to say the least since I was preparing my self to having to pull the head and cart it over to a machine shop. Thanks again for the speedy and good advice guys. This is why this is the best LSX site out there!
07-22-2011, 03:14 AM #6None Shall Pass
- Jan 2010
Glad it worked out easy for you.
07-22-2011, 04:26 AM #7
Good to hear! I can only imagine the panic you felt when you realized what had happened.
07-22-2011, 11:27 AM #8BANGIN GEARS>STAB N STEER
- Nov 2009
- Jacksonville FL
HONDAS ARE LIKE TAMPONS... EVERY PUSSY HAS ONE!
**PHK**
07-22-2011, 12:47 PM #9
Help: Broken intake bolt in head. HELP!
By BLK2KSS in forum General HelpReplies: 5Last Post: 07-22-2011, 11:22 AM -
Easiest way to remove a broken bolt in the head?
By Lunatikgixxer in forum General HelpReplies: 28Last Post: 04-30-2011, 08:12 AM -
Broken/Snapped/Stripped bolt head? Look here
By Hi-Po in forum ToolsReplies: 9Last Post: 02-17-2011, 09:59 AM -
Broken header/head bolt.
By 98maro in forum General HelpReplies: 14Last Post: 01-14-2011, 11:12 PM -
broken intake bolt
By mobileone in forum External EngineReplies: 6Last Post: 07-07-2006, 07:26 PM
. The cursing did indeed come later though of course
