Results 1 to 16 of 16
Thread: Broken Bolt
    Jun 2012
    florida
    Broken Bolt
    I noticed a broken exhaust bolt. Drivers side close to the fire wall. Exhaust never off the car, whats the deal.
    Is there enough to be able to get a grip on it?
    How far into the cylinder head is it?
    You may need to remove the head in order to get it out.
    Surprise you haven't had any leaks yet.
    Jun 2012
    florida
    Bolt
    its broken off flush with the manifold. I am suprised it does not leak either.
    You may be lucky in that you might have just enough of the bolt to be able to take it off with some vice grips. You'll have to remove the manifold to do this. Also use liberal amounts of PB Blaster to get it out. And use anti-seize on install.
    phoenix
    04 2500 4x4 crew cab
    I seriously doubt you will get it out any conventional way. I bet if you look on the pass side, you will notice missing and or loose bolts. I think the reason for this is the way the engine rotates. It torques drivers side tight, and pass side loose.
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    I had the same damn problem happen to me when I was replacing my header gaskets. Mine broke off the head and it was passenger side next to the firewall, I ended up taking it out with some channel lock pliers after 2 hours and lots of cursing.
    It is now my trophy.
    Jun 2012
    florida
    Bolts
    I looked, its the only broken one on the engine.
    phoenix
    That's good news. Prob just leave it till the heads need to come out. Or, if you are feeling adventurous, try for it if/when you do LT's.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Quote Originally Posted by az gt eater View Post
    When you do your LT's get ARP bolts and use plenty of anti seize on them.
    Coral Springs, Fl
    Sunset Orange Metalic
    Agreed, takke the manifold off, soak the hell out of it with some pb blaster or other penetrating oil for a few hours, put some vise grips on it, and try not to snap the rest off
    Jun 2012
    florida
    Its the head, not the manifold.
    Coral Springs, Fl
    I understand that, but it would be a lot easier to remove with the manifold out of the way
    Jun 2012
    florida
    engine
    Somtimes I think it would be easier to remove the engine to work on it. Has anyone ever removed one from above?
    Yes, but it is a PITA.
    remove hood, wire grounds, intake, heads, exhaust manifolds, transmission. That is to just get the block ready for removal. There's more but just giving the highlights.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    im pretty sure the manifolds arent threaded, so if you take the other bolts out, and the manifold off, you should have 1/4 inch or so of threads sticking out to get some vise grips on
    phoenix
    If the bolt is broken off flush with the manifold, then you are correct.
  1. Broken Header Bolt?
    By etownfbplayer in forum External Engine
    Last Post: 05-09-2010, 07:24 AM
  2. broken header bolt
    By tonyjnjz in forum External Engine
    Last Post: 04-30-2007, 03:16 PM
  3. Broken Bolt
    By bealschad in forum Internal Engine
    Last Post: 02-22-2007, 02:48 PM
  4. Broken rocker bolt, what to do?
    By andrewdruiz in forum Internal Engine
    Last Post: 07-18-2006, 04:20 PM
  5. broken intake bolt
    By mobileone in forum External Engine
    Last Post: 07-07-2006, 07:26 PM
