Thread: Broken Bolt
    Member bealschad's Avatar
    somerset PA
    1998 ws6 trans am
    Broken Bolt
    Well i was putting in a new cam ,lifters,oil pump,timing chain, and valve springs. When i was tearing the motor down i found a broken bolt. Passenger side head bolt the one in the back middle. I went to loosen it and it was loose. So i removed the nut just thinking that the nut was loose.
    When i went to put the head back on I noticed that the stud was loose. (By the way it has ARP bolts.) So when i went to tighten the stud i had found that it was broken off 1 1\2 IN down it the block.
    I put over 6000 miles on the car with the stud broke (I guess it has been broke for awile.) The head gasket never leaked so should i try to retracted the broken stud or just hope it seals again???
    The motor is still in the car so it's hard to get to. Any suggestion or how too's????????????????
    Jun 2006
    go for it, let us know what happens.
    somerset PA
    1998 ws6 trans am
    I fixed it delet this thread
    Impounded unkind's Avatar
    Feb 2007
    Lake TiTiPo0p
    98 camaro
    Arkansas
    99 Trans Am
    your not going to let anyone know how you fixed it?
  1. Broken Bolt
    By johnfin in forum Firebird / WS6
    Last Post: 09-07-2012, 03:33 PM
  2. Broken Header Bolt?
    By etownfbplayer in forum External Engine
    Last Post: 05-09-2010, 07:24 AM
  3. broken header bolt
    By tonyjnjz in forum External Engine
    Last Post: 04-30-2007, 03:16 PM
  4. Broken rocker bolt, what to do?
    By andrewdruiz in forum Internal Engine
    Last Post: 07-18-2006, 04:20 PM
  5. broken intake bolt
    By mobileone in forum External Engine
    Last Post: 07-07-2006, 07:26 PM
