    Lancaster, CAlifornia
    Dark Green
    1994 Camaro
    dvd parking brake
    I installed an indash dvd hu but i do not know where to run the parking brake lead. is it one of the wires at the brake itself or some other location. and color. thanks!
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    what head unit? the wire usually goes to ground side of the switch. check the instructions for the unit.
    Pistol Pete '96 Z28SS's Avatar
    Cowboy Country Stillwater, OK
    Bright Rally Red
    1996 Camaro SS
    is there some dummy location you can put it so you can run the DVD anytie you want?
    Dark Green
    1994 Camaro
    it is a dual 8181. i grounded the parke brake wire to the chassis and found the factory codes to diable it. thanks!
    LA
    Grey
    2010 Camaro 2SS/RS CGM
    i installed a switch with mine, i took the lead for the parking brake and branched off a wire from the amp relay, when you want it to play dvd's you flip the switch on.
    Dark Green
    1994 Camaro
    i was going to use a switch, i got a lot of little ones laying around, but after i put in the factory disable codes, i didnt need to, so turned out to be much easier and i dont have to deal with the switch. thanks though!
    Aug 2006
    maryland
    yellow
    2002 trans am
    Just pull the brake up or down one click. this way the brakes dont engage but the headunit will read that it is on.
  1. Question: parking brake
    By jodmari in forum Firebird / WS6
    Last Post: 12-23-2015, 03:27 AM
  2. parking brake
    By slimss in forum GM Trucks
    Last Post: 04-26-2012, 07:59 AM
  3. Parking brake
    By c5z28 in forum General Help
    Last Post: 12-07-2010, 02:56 PM
  4. parking brake Q
    By corlain in forum General Help
    Last Post: 07-13-2010, 04:56 AM
  5. parking brake
    By pyro449 in forum GTO
    Last Post: 09-03-2007, 12:07 PM
