Results 1 to 17 of 17
Thread: parking brake Q
    Riverton, WY
    1995 Z28 Camaro
    parking brake Q
    not sure if this question belongs here or in the LT1 section, since i think LT1 parking brakes are different from LS1, but does anyone know how to adjust the parking brakes on a 95 camaro?
    If it happens to be the same as the later year cars, you fully engage and release the parking brake 3 times. It is supposed to be self adjusting. If that is not how it is done, it most likely has a threaded rod either at the parking brake handle mechanism or underneath the car in the tunnel. Someone on here should know for sure.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Pumping the e brake handle should automatically adjust the rear calipers.
    Riverton, WY
    1995 Z28 Camaro
    thanks. since they didnt self adjust though i assume they are too far out of adjustment or something? i just had the rear rotors and calipers replaced, and when i got it back the ebrake handle had no tension till almost all the way up, and in no position does it give any roll resistance. im going to look today for a threaded rod or something on the cable to adjust it with. i found this website http://shbox.com/1/adjparkingbrake.jpg but cant make heads or tails of the diagram, and am not for sure "free travel" is what i need to adjust.
    If it is anything like the '98 - '02 setup, chances are the rubber boot on the parking brake lever (at the backing plate) has disintegrated. After this happens, all sorts of road grime and moisture gets in there and things eventually get rusted up. It's not too bad to rebuild the parking brake -- this is a before and after pic of mine just to give you an idea of what it looks like:
    The lever that the parking brake cable attaches to forces the drum pad against the inside of the brake rotor when engaged. There is a self adjuster assembly that is essentially identical to that of a rear drum brake equipped car. Chances are that is what is frozen and is preventing your brakes from adjusting.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    on my car....the e-brake doesnt catch until like...the last 2 clicks..
    sometimes when i pull up on it, it clicks one time, then offers no resistance and goes all the way up...but holds.
    will this pumping help mine? it feels like my cable is stretched or something
    It should, unless your adjusters are frozen. It certainly will not hurt anything to try. Hold the button in and do it 3 times -- see what happens.
    Riverton, WY
    1995 Z28 Camaro
    thanks for the help but i probably should have at least taken the wheel off and looked before asking; the mechanic didnt have it assembled quite right, so the cable wasnt actuating a little rod that forces the pad against the wheel. fixed on accident by taking a spring off, then the rod just fell into place where it was supposed to be. The driver side is also fucked up, but i think it just has to do with the cable on that side (can be moved by hand but the pressure applied by the parking brake isnt strong enough to actuate the lever on the assembly.
    Good to hear. Is your parking brake similar to the pic I posted?
    Riverton, WY
    1995 Z28 Camaro
    thankfully i didnt have to take it far enough apart to find out. be about a month before i could tell you; got to tear most everything apart then and clean tons of rust off and replace some things then. ive only had it since august and dont treat it like i should, and 130 000 miles means some things are starting to go wrong. from the head gasket to the pinion seal, ive got my work cut out for me.
    might be on here a little more then lol, getting help especially if i decide to change the build significantly.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Hmmm...the pics Jeff posted look similar to mine. I had the same problem a few months ago. Turned out to be misadjusted parking brakes. My manager and I took the rear drums off and found the rear shoes still looked new. Although my manager had to heat up the right rear adjuster rod as the gear was seized to the rod. Now it takes about 8 clicks to engage and the lever doesn't go all the way up as it did when I first bought it.
    Excellent thread.
    Quote Originally Posted by corlain View Post
    When you get things apart, be sure to clean and lube your caliper pins with synthetic caliper grease. They tend to seize up on our cars if not routinely serviced. The pinion seal leak on the 10 bolt is a factory installed option -- they just about all do that. If it is simply wet, and not dripping on the ground, you may want to save yourself the trouble and skip this. Lots of guys have fixed them and they just start weeping again soon thereafter.
    Riverton, WY
    1995 Z28 Camaro
    thanks pajeff, preciate the advice.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    The lt1 has the parking brake as part of the caliper. It has a lever that pushes the piston in the caliper.
    Refusing to grow up cyeagle's Avatar
    Coral Springs, Fla
    '01 Camaro SS
    Parking brake lever boot
    I figured out why I haven't had any parking brake for--well-- years
    Thought it might just be an adjustment thing, pulled the wheels and discovered both levers just flopping around and the cables are attached. Pulled the rotors and discovered the pin inside the plunger was not in the cup of the lever. When the shop put the Moser 12 bolt in the F'd it up.
    Anyway the boots are shot. They are no longer available from GM.
    Anyone the remedy ??
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    how about this thread entitled " Replacement Parking Brake Boots "
    Coral Springs, Fla
    '01 Camaro SS
    Again you're the man !! Thanx
    '07 ZO6, Red , stock for now
    '01 SS M6,MTI lid, F.R.A.M.,B.P.P MAF,coolant bypass,SLP 160 therm.SLP 1.85 rockers,SLP pulley,Drill mod,SLP STB,SLP SFC's,SLP D/S loop,Lou's S/S,BMR T/A,BMR LCA's,BMR LCA brackets,Bilstein's,Moser 12 bolt 3.73's, Nitto's, NOS 5177,MSD window switch
  1. Question: parking brake
    By jodmari in forum Firebird / WS6
    Last Post: 12-23-2015, 03:27 AM
  2. parking brake
    By slimss in forum GM Trucks
    Last Post: 04-26-2012, 07:59 AM
  3. Parking brake
    By c5z28 in forum General Help
    Last Post: 12-07-2010, 02:56 PM
  4. parking brake
    By pyro449 in forum GTO
    Last Post: 09-03-2007, 12:07 PM
  5. dvd parking brake
    By slipping in forum Stereo and Electronics
    Last Post: 12-21-2006, 05:59 PM
