Thread: parking brake
    Nov 2009
    bernaillio county
    navy blue
    2002 camaro ss
    parking brake
    What would cause my parking brake light to flash and beep when the e brake pedal is not engaged??? I checked brake fluid level and it was at correct level, also pulled up on e brake pedal and it still continues to flash. The brakes feel fine. Its a 1999 chevy silverado 4 wheel drive
    USA
    Velocity Yellow
    2008 Corvette Z06
    Is the ABS light on as well?
    Could be something as simple as the parking brake pedal sensor, or brake fluid level sensor.
    Nov 2009
    bernaillio county
    navy blue
    2002 camaro ss
    No ABS light on, only parking brake light is flashing and beeping.
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    i didnt know they could beep in all the cars and truck i have worked on or bin in none have beeped from a brake like. any way try looking at the switch on the pedal you may of had the end of it brake off and if it did you can pull all day long and its not going to day any thing
    USA
    Velocity Yellow
    2008 Corvette Z06
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    Read your owners manual.. lol sometimes it will tell you why it could be flashing and beeping.
    Nov 2009
    bernaillio county
    navy blue
    2002 camaro ss
    Ok the reason the parking brake light was flashing and beeping when the parking brake was not depressed is because the truck had a wheel cylinder leaking which caused uneven hydraulic pressure in the brake system. Which means one side of the brake system is working harder than the other side.
    the parking brake light is also a warning light for the whole brake system.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by slimss View Post
    Makes sense... I guess I should have asked if it was 4 wheel disc, or rear drums. I'm glad you found out what the issue is!!!
  1. Question: parking brake
    By jodmari in forum Firebird / WS6
    Last Post: 12-23-2015, 03:27 AM
  2. Parking brake
    By c5z28 in forum General Help
    Last Post: 12-07-2010, 02:56 PM
  3. parking brake Q
    By corlain in forum General Help
    Last Post: 07-13-2010, 04:56 AM
  4. parking brake
    By pyro449 in forum GTO
    Last Post: 09-03-2007, 12:07 PM
  5. dvd parking brake
    By slipping in forum Stereo and Electronics
    Last Post: 12-21-2006, 05:59 PM
