    Red03SVTVert
    Guest
    Compression test on Ls1 in C5
    My buddy has a C5 with an Ls1. He had a little problem and we want to do a compression test to make sure everything internal is up to par. How many PSI should I see on a healthy motor. I have searched everywhere and found nothing. Also, what is safe to be disconnected so the engine will turn over and not fire. TIA any tips would be appreciated.
    Iroc89
    Guest
    Try going to Ebay and looking up Ls1 motors for sale. Usually they will have a new one or a used one and they usually tell you the Compression ratio that the engine is running.
    BlackHawk T/A
    Guest
    He doesn't want to know the CR he wants to know the PSI each cylinder should hold during a compression test...
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    should be in your repair manual if you have one...i think it's 175 psi. I'm having a prob finding a haynes or a chilton for our cars
    Yardley, PA
    i think if they are within 10% of each other is more important then the psi they are at. Of course there is a range defined, check the shop manual, but if you have one cylinder more then 8-10% out, there might be a problem
    Quote Originally Posted by SeVeReDiStOrTiOn
    Having and using a Haynes or Chilton is like buying a band aid for a shotgun wound.
    Pretty damn worthless.
  1. Compression test question?
    By MasonWS6 in forum Internal Engine
    Last Post: 05-21-2016, 02:42 PM
  2. LS1 compression test
    By Double0me in forum Internal Engine
    Last Post: 01-14-2012, 04:01 PM
  3. Compression test questions
    By PaddycakeFTW in forum Internal Engine
    Last Post: 05-09-2011, 02:47 PM
  4. Question: how much would a compression test go for?
    By Eganslp in forum Camaro / SS
    Last Post: 01-15-2011, 10:53 AM
  5. Bad Compression Test!!!
    By ckcmatt in forum Internal Engine
    Last Post: 09-05-2007, 01:43 PM
