    May 2011
    Elk Grove, CA
    1954 Ford Customline
    Compression test questions
    I bought a '98 LS1 from a guy on Craigslist last week. I spent a few days stripping the accessories and crud off and ended up with a decent-looking long block on an engine stand.
    I decided to do a compression test before going any further. Spinning the motor over by hand, all cylinders came up between 50-60 psi after three full compression cycles.
    Cylinder #1 was the slowest to get there. Also, if I put my hand over the intake port as it was compressing, I could feel a puff of air blasting back at me.
    I've never done a compression test on a non-running engine before. I don't expect to see numbers in the 150 psi range when cranking slowly by hand, but I'm still wondering if my readings are "normal" and whether there's something wrong with the valve or seat in cylinder #1 (and potentially others).
    Just looking for opinions. Should I get the heads redone? Should I hook up the starter and battery and get new readings? Should I stop worrying and get my car on the road?
    Advice would be appreciated. Thanks in advance.
    Eric
    The only way to get a good test reading is to spin the engine with the starter. Rotating the crank by hand is simply too slow and all the compression bleeds off.
    May 2011
    Boston Ma
    2002 WS6 Trans Am
    Just a note. Make sure all the plugs are removed and crank with the starter. If your feeling a puff of air on compression the valve seats are leaking on number 1.
    May 2011
    Elk Grove, CA
    OK, I'll run the test again tonight. Thanks.
    Quote Originally Posted by GBurke View Post
    Good point. OP: If you have a cylinder with low compression, add a teaspoon or so of oil down the plug hole and try it again. If the compression pops up to where it should be you have a ring sealing issue. If the oil results in no change it has to be the valves... or a hole in the piston.
  1. Compression test question?
    By MasonWS6 in forum Internal Engine
    Last Post: 05-21-2016, 02:42 PM
  2. LS1 compression test
    By Double0me in forum Internal Engine
    Last Post: 01-14-2012, 04:01 PM
  3. Question: how much would a compression test go for?
    By Eganslp in forum Camaro / SS
    Last Post: 01-15-2011, 10:53 AM
  4. Bad Compression Test!!!
    By ckcmatt in forum Internal Engine
    Last Post: 09-05-2007, 01:43 PM
  5. Compression test on Ls1 in C5
    By Red03SVTVert in forum General Help
    Last Post: 09-30-2005, 04:58 AM
