Results 1 to 1 of 1
Thread: LS1 compression test
01-14-2012, 04:01 PM #1
this is a referance and question (referance because I couldnt fine anything online), I ran my car hot due to a radiator hose blowing about 8 miles from home. It took me 1.5 hours of driving for about 90 seconds and then letting the car cool. So I just did a compression test to make sure I didn't hurt anything. My results are as follows. #1: 120/120/120 #2: 130/130/130 #3: 133/129/129 #4: 125/124/120 #5: 120/120/125 #6: 130/130/134 #7: 125/126/126 #8: 125/127/125
Process was easy as all I had to do was remove the fuel pump fuse up front and the spark plugs, screw in the the compression tester hose in each hole/cylinder. Turn the key until I heard the engine turn over 3x (could have gone 4 but as long as you do the same each time your good). So what I was wondering was for a stock engine/pistons and rings are these numbers acceptable?
Modifications are
P1SC intercooled ProCharger, 60lb injectors, 255lph pump, LS6 intake, 85mm TB, 12 bolt Moser, suspension and other non relevant engine stuff.
Compression test question?
By MasonWS6 in forum Internal EngineReplies: 13Last Post: 05-21-2016, 02:42 PM -
Compression test questions
By PaddycakeFTW in forum Internal EngineReplies: 4Last Post: 05-09-2011, 02:47 PM -
Question: how much would a compression test go for?
By Eganslp in forum Camaro / SSReplies: 2Last Post: 01-15-2011, 10:53 AM -
Bad Compression Test!!!
By ckcmatt in forum Internal EngineReplies: 3Last Post: 09-05-2007, 01:43 PM -
Compression test on Ls1 in C5
By Red03SVTVert in forum General HelpReplies: 5Last Post: 09-30-2005, 04:58 AM
