Results 1 to 14 of 14
Thread: Compression test question?
08-30-2015, 01:36 PM #1Junior Member
- Jun 2014
- Connecticut
Black- 99 Trans Am WS6
So I just finished a compression test on my ls1. The driver side cylinders all came up to be 175 psi. The passenger side however only cyl #8 & #6 came up to 175psi. 2 & 4 came up 150psi. I did cyl #2 twice. The first time it came up to 130, second time was 150. I am trying to see if I have a bad head gasket. 150 from 175 doesn't seem like a drastic drop but then again I'm loosing coolant slowly. I guess what I am trying to ask is what should be the standard psi. Also should I check the intake manifold?
08-30-2015, 02:07 PM #2
There is no coolant crossover on an LS1 so the intake would have nothing to do with a loss of coolant.
A couple of more tests that you can complete. Squirt about a tablespoon of clean engine oil into each of the cylinders that tested low and the repeat the test. If the compression jumps up it is likely that you have an issue with the rings or cylinder walls. If the compression stays low, then you have either a valve issue or head gasket issue. Is the engine overheating? Another thing you can do is pressure test the cooling system. You can "rent" a tester from a chain parts store and see if the cooling system loses pressure. Have any friends with a bore scope?
08-30-2015, 02:33 PM #3Junior Member
- Jun 2014
- Connecticut
Ok thank you, I'll try the oil trick. And no the engine is not overheating but did start puffing white smoke that smells like burnt antifreeze. There's no visible leaks on the motor
08-30-2015, 03:29 PM #4
Let us know what you find.
09-02-2015, 06:29 AM #5Former Mopar Man
- Jun 2011
- Branchville, NJ
09-02-2015, 08:07 AM #6
That's how I roll, dawg.
09-08-2015, 01:39 PM #7Junior Member
- Jun 2014
- Connecticut
So the compression test is leaning towards head gaskets. I tore everything down to the heads and I'm going to have someone with more experience to take them off, make sure the heads are straight and put the new gaskets on
09-08-2015, 06:36 PM #8
Any pics of the project?
09-08-2015, 06:41 PM #9Junior Member
- Jun 2014
- Connecticut
This is as far as I got
09-08-2015, 06:45 PM #10Junior Member
- Jun 2014
- Connecticut
09-09-2015, 10:30 AM #11
Mason - upload your pics to a free photo sharing site like Photobucket or Image Shack. Once uploaded, simply copy and paste the [IMG] code for each photo into your post on here.
09-13-2015, 04:10 PM #12Former Mopar Man
- Jun 2011
- Branchville, NJ
I can't get the pictures up.
03-17-2016, 03:17 PM #13
Adding oil to a motor with dished pistons just raises the compression ratio, a leak down test will tell you where the compression is going. It could be a problem with how your crank vents are hooked up or valve seals also. Turbos can leak oil also.
John
05-21-2016, 03:42 PM #14Senior Member
- Feb 2006
- Orange County, NY
You can try a leakdown test also. If you pull the radiator cap while pressure is in the cylinder you will hear air or see bubbles.
LS1 compression test
By Double0me in forum Internal EngineReplies: 0Last Post: 01-14-2012, 05:01 PM -
Compression test questions
By PaddycakeFTW in forum Internal EngineReplies: 4Last Post: 05-09-2011, 03:47 PM -
Question: how much would a compression test go for?
By Eganslp in forum Camaro / SSReplies: 2Last Post: 01-15-2011, 11:53 AM -
Bad Compression Test!!!
By ckcmatt in forum Internal EngineReplies: 3Last Post: 09-05-2007, 02:43 PM -
Compression test on Ls1 in C5
By Red03SVTVert in forum General HelpReplies: 5Last Post: 09-30-2005, 05:58 AM
