Results 1 to 13 of 13
    Feb 2006
    clovis,california
    pewter
    01 camaro ss
    clutch pedal safety start help
    i have an lt1 t/a 6spd. to make sure you understand what i'm talking about, it's the thing that prevents the car from being started with the clutch pedal not depressed. if i press the pedal all the way down it won't start, like its supposed to, i have to lift on the pedal for it to "find the spot where it will start." i can't seem to find how to fix it or bypass it. anything will help, thanks.
    p.s. honda=
    Junior Member Json27's Avatar
    Aug 2006
    Alabama
    2001 Trans-Am
    Sounds weird to me. I will contact a friend of mine and see what we can come up with. I'll post the info I find out.
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Clutch Pedal Position SW
    There is a clutch pedal position switch located at the top portion left hand clutch lever bracket assembly.
    It is held in postion by (2) bolts that fit through oblong holes in a mount bracket. Shaped like a sandwich. The Clutch Anticipate SW is to the right of it and fits through a round hole.The position sw has the wire bundle coming in from your left. See if it is loose. Hope this helps. I attempted to up load a picture for you but can't figure it out (too large). If you can't locate it email me: [email protected] and I will forward the picture.
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    Member edbird's Avatar
    hammond Ind
    1999 trans am convert
    It is noyhing more than an on/off switch.One wire going in,one coming out.If you put the two wirs together,the car will always start even when in gear!If you put those two wires to a kill switch,car will only start when you turn switch on.
    Member anniversary30's Avatar
    Illinois
    White/Blue
    99 Trans Am
    Myself, I wouldn't bypass it . What happens if for some reason you forget it is in gear and start it while you are behind another car.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by anniversary30 View Post
    then you dont deserve to drive a m6
    hammond Ind
    Dittos,shady milkman!!
    sounds to me like it's out of adjustment. Even if you have to replace the switch it's a cheap and easy fix.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    You laugh but I saw a perfect example of why you want the clutch safety. Guy had his bypassed in his S-10 pickup. Girlfriend sitting in passenger seat want to turn on the radio while we are all outside the vehicle chatting. She accidently turns the key the wrong way and you can guess the rest. The worst part was the gf/bf shouting match that ensued of course-nobody was hurt that time but.........
    Shepherd, Michigan
    98' trans am
    i still laugh becuase thats what parking brakes are for.
    Grilled Cheese rocks!!!!! slo4mula's Avatar
    Cedar Falls, IA
    GM Bright Red
    2000 Formula
    Then why do automatics have parking brakes???
    j/k
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by slo4mula View Post
    j/k
    man i'm digging the avatar....i am duncan McCloud from the clan McCloud...good shit "there can only be one" brings back memories when i was a lil kid..i'd watch all the movies and the series and go play with fake swords
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    I always wonder why ppl with automatics use their parking brakes. I could understand maybe being parked on a steep incline or something but I've gotten in customers cars parked on level ground with the parking brake on-why?? Anyway, wanted to point out that a starter motor has enough torque to overcome the parking brake in a stickshift car. The motor won't want to start but it will move the car with ease. It's a long story how I know this-don't ask .........
  1. Clutch Pedal Pressure and Smelly Clutch
    By race5050 in forum Manual Transmission
    Last Post: 01-06-2010, 05:37 PM
  2. Light Clutch Pedal (New Clutch)
    By Rhinohuey in forum Manual Transmission
    Last Post: 09-14-2007, 02:41 PM
  3. Fading Clutch Pedal with new clutch
    By mrbob2 in forum Manual Transmission
    Last Post: 08-17-2007, 05:58 PM
  4. clutch safety switch
    By turbols1chick in forum Firebird / WS6
    Last Post: 12-26-2006, 04:39 AM
  5. clutch pedal safety start help
    By ws6/ss in forum Manual Transmission
    Last Post: 11-01-2006, 11:15 PM
