Results 1 to 2 of 2
01-06-2010, 01:01 PM #1Junior Member
- Nov 2005
- La Crescenta
Red- 2002 TransAm Firehawk
Clutch Pedal Pressure and Smelly Clutch
Stock 2002 Firehawk w/ standard slp mods...cold air intake, slp exhaust, etc. I replaced stock clutch at around 78K miles with a Ram pressure plate and disk. I now have 80K miles. It's not a race clutch, just one step up from the standard replacement they recommend. The clutch works fine, but I have two complaints:
1. The pedal pressure is very heavy. I didn't notice it at first, but I've developed a left-knee problem ever since I installed it. Maybe it's age (I'm 43), but I never had a problem with the stock clutch.
2. The clutch puts out a very bad "smell" when I slip the clutch. For example when I back-up quickly or if I take off quickly. It doesn't smell like the typical burnt clutch smell, it smells like CNG.. natural gas. Yuck!
Generally the clutch works well, but keep in mind that I don't hammer on the car and I'm pretty easy on clutches. The "smelly" clutch is kind of emabarrassing because I have to explain where the smell is coming from if someone's in my car (for obvious reasons).
Does anyone know if the LS7 clutch set-up has a relatively light clutch pedal pressure? or can you recommend any other clutch set ups that have a lighter clutch pressure at the pedal? I remember reading that the centerforce clutches has weights on it to make the clutch pedal pressure feel lighter. I'm going to have to sell the car if I can't resolve the issue since my knee can't handle the additional pressure.Last edited by race5050; 01-06-2010 at 01:05 PM. Reason: add to title
01-06-2010, 05:37 PM #2Senior Member
- Apr 2008
- Madison, WI
I've heard the LS7 feels exactly like the stock setup, so that may be what you want.
Clutch pedal losing pressure?
By redbird555 in forum Manual TransmissionReplies: 0Last Post: 06-12-2012, 08:43 AM -
No pedal pressure after clutch install
By chevyss1234 in forum Manual TransmissionReplies: 7Last Post: 12-23-2009, 06:23 PM -
Light Clutch Pedal (New Clutch)
By Rhinohuey in forum Manual TransmissionReplies: 2Last Post: 09-22-2007, 08:51 PM -
Fading Clutch Pedal with new clutch
By mrbob2 in forum Manual TransmissionReplies: 2Last Post: 08-17-2007, 05:58 PM -
z06 clutch for sale, pressure plate clutch disk and flywheel
By themack56 in forum Parts For Sale / TradeReplies: 2Last Post: 07-06-2006, 07:15 PM
