Results 1 to 3 of 3
08-14-2007, 09:14 PM #1Junior Member
- Oct 2006
- Southern California
Red- 1999 Z28 Convertible
Fading Clutch Pedal with new clutch
I just put a new LS7 clutch in my car. It had 46K on the original clutch. I thought the clutch was going bad because the clutch was slipping and the pedal was really low. We found that the slave cylinder was leaking inside the bell housing and the clutch was full of oil. The flywheel and pressure plate were both burned.
The pedal is still falling to the floor. I sat at a light with a light pressure on the pedal and it started to go to the floor. It went down to the floor and the light turned green. I suspect that the clutch master cylinder is leaking internally. I have read that GM is having some problems with these. IS that true? IS there a bulletin out on this problem?
Any recommendations would be greatly appreciated.
Thanks, Bob
08-17-2007, 05:01 AM #2
did you bench bleed the master?
08-17-2007, 05:58 PM #3Junior Member
- Oct 2006
I finally got a good clutch
I had a new master cylinder put on. The first one they put on failed. The second one was the answer. I got a full pedal with no fade. For the future I would recommend changing the clutch master cylinder along with the slave cylinder. It may cost more but it sure will keep you from being bummed out when your new clutch does not work
Bob
Clutch pedal
By FIREHAWK0078 in forum Manual TransmissionReplies: 4Last Post: 09-03-2012, 01:54 PM -
Clutch Pedal Pressure and Smelly Clutch
By race5050 in forum Manual TransmissionReplies: 1Last Post: 01-06-2010, 05:37 PM -
clutch pedal :gone:
By IZNUTHN in forum Manual TransmissionReplies: 8Last Post: 10-15-2008, 02:31 PM -
Light Clutch Pedal (New Clutch)
By Rhinohuey in forum Manual TransmissionReplies: 2Last Post: 09-22-2007, 08:51 PM -
By Rhinohuey in forum Manual TransmissionReplies: 5Last Post: 09-14-2007, 02:41 PM
