Results 1 to 10 of 10
    Junior Member turbols1chick's Avatar
    plano,tx
    2002 ws6
    clutch safety switch
    hey guys this is the 3rd time my car has not started. i have already replaced the clutch safety switch and i think it might be the fuse. i doesnt crank or click at all know its not the battery i just replaced that with a yellow top. and i dont think it the starter so it must be the fuse right? anyways i would just like to see if anyone has had the same problem or has an advice. thanks
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Could be a problem with the VATS (Vehicle Anti Theft System) has your security light been coming on or flashing ?
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    plano,tx
    2002 ws6
    just flashing like normal when ever the car is locked. you wouldnt happen to have a diagram of all the electrical stuff for our car would you?
    boiling springs
    93 trans am
    my friends 01 t/a did the same thing and we replaced the starter and it hasnt messed up since.... get under it and hit the starter and wiggle some wires if it cranks after that it the starter
    plano,tx
    2002 ws6
    so m=now it starts sometimes but i didnt think it was the starter i got under the dash and held the switch and got it started once and then the it happened agian holding the switch didnt work. but then after waiting a few minutes i tried it pushed the clutch in and turned the key for like 15 sec and then it started...... so i dont think its the starter maybe i should just get rid of the switch does anybody do that?
    Aug 2000
    Indy
    I'de just replace the starter, don't hear of switches going bad.
    boiling springs
    93 trans am
    well forgot to say that we also straight wired his switch also
    plano,tx
    2002 ws6
    HMMM well i think i might just wire it and if that doesnt work then get a starter. btw does anyone have a wriring diagram or know where i can find one ?
    Aug 2000
    Indy
    you got pm
    plano,tx
    2002 ws6
    yes
  1. where is the ignition nuetrel safety switch located?
    By qwik219d9 in forum General Help
    Last Post: 08-29-2014, 03:18 PM
  2. Question: Engine won't crank, not VATS, clutch safety switch, battery
    By 318Charger in forum General Help
    Last Post: 09-09-2010, 04:03 PM
  3. FJO and/or Fuel Pressure Safety Switch
    By captainwizbang in forum Nitrous
    Last Post: 09-04-2007, 11:21 PM
  4. clutch pedal safety start help
    By ws6/ss in forum General Help
    Last Post: 11-06-2006, 03:36 PM
  5. clutch pedal safety start help
    By ws6/ss in forum Manual Transmission
    Last Post: 11-01-2006, 11:15 PM
