Results 1 to 3 of 3
09-03-2007, 06:31 PM #1Junior Member
- Aug 2007
- Texas
Maple Red- 2000 TA
FJO and/or Fuel Pressure Safety Switch
I picked up an FJO WBAFR to use with my Maximizer II. Since I can monitor for a lean condition with the FJO, should I still install a Fuel Pressure Safety Switch?
09-03-2007, 07:13 PM #2
sure. can't have enough safety points.
09-04-2007, 11:21 PM #3
Yes you do still install the fuel pressure switch.
That is a must for safe install.Don't be afraid of the bottle!!! Be afraid of your tune!!!
where is the ignition nuetrel safety switch located?
By qwik219d9 in forum General HelpReplies: 1Last Post: 08-29-2014, 03:18 PM -
Question: Engine won't crank, not VATS, clutch safety switch, battery
By 318Charger in forum General HelpReplies: 19Last Post: 09-09-2010, 04:03 PM -
By turbols1chick in forum Firebird / WS6Replies: 9Last Post: 12-26-2006, 04:39 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM -
Looking for gauges! nitrous pressure, fuel pressure!
By texasss in forum Parts Wanted / TradeReplies: 2Last Post: 10-29-2005, 09:05 AM
