    Houston
    2002 WS6
    Question Suspension Question....
    I want to lower my 2002 WS6 w/ the Eibach Pro Kit. I will be adding LG Subframe Connectors @ the same time. Will I need an adjustable PHB to get my rear end right?
    Houston
    2002 WS6
    Anyone?
    386HP 373TQ jwindbigler's Avatar
    San Diego...Michigan originally
    1999 Trans Am 5.7L
    Rather than waste money on the Eibach pro-kit, I would get rear coil overs. This will still drop your car about 3/4 of an inch in the rear...so I'm told. You can adjust your spring rate from 130-250ft-lbs. This for about $580 plus S&H. I saw them on ws6store.com. They will be able to answer any questions that you may have. These springs will help you with your holeshot, and provide you with better traction while cornering. This combined with your subframe connectors, you will see a world of difference. Hope this helps.
    1999 Trans Am 5.7L
    Here's a link to the single adjustable
    http://www.ws6project.com/user_stor/...ffe12d7a1e9b6e
    1999 Trans Am 5.7L
    Depending on how much you want to spend. They have a double coil over too. Here's the link for that
    Smithdale, Mississippi
    Pewter Metallic
    2000 Trans Am WS-6
    Stankeric. Do you all ready have the Eibach Pro Line Kit? I just removed
    a set from my WS6 that I had on around two months. I live in the country
    and the roads won't allow me to run that low. It looked great and handled
    the road like glue. The springs are allready mounted on new front struts that I'll let go with the kit. Let me know if you are interested in them.
    a_billy@bellsouth.net
    Quote Originally Posted by Stankeric View Post
    The Eibach springs with give you a nice stance and much improved handling. Yes an adjustable panhard bar is a wise choice. Also look into installing a set of lower control arm re-location brackets to compensate in the geometry change of the suspension. With these parts you will be able to better advantage of your new springs. Good Luck!
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    An adjustable PHB went in at same time as my pro-kit, shocks, SFC & LCA's but I don't know if really needed it or not. They are sorta cheap so I thought why not.
    Panama City Beach, Florida
    Yes.
    bunch of them
    Yes, you need an APH.
    2002 WS6 M6 454 LSx
    2000 Camaro SS M6
    2000 WS6 M6->A4
    2004 Silverado SS
    2004 GTO A4
    2002 Grand Prix GTP sdn
    2006 Envoy Denali
    1999 GMC Slonoma
    1999 "Project LS10"
    1996 Impala SS
    www.panamacitylsx.com
    KWK N NUF TheKitchenSink's Avatar
    Arlington Heights, Illinois
    2001 Trans Am WS6
    Is a single or double adjustable recommended? What is more common, im looking to get one soon, Dont know if I should spend the extra money on a double adjustable or not, only difference I see is that you can adjust it w/o removing it w/ a double adjustable and w/ a single you need to remove it to adjust it.
    Pacesetter Headers & ORY, Magnaflow Catback, P&P TB, Koni SA Shocks, Strano Lowering Springs, TSP228R, PRC Dual Valve Springs, LS6 Ported Oil Pump, Vig. 3200 Stall, TransGo Shift Kit, Trans Cooler, Spohn Panhard Bar, UMI Rear LCA's, Relocation brackets, Torque Arm SFC. 411 hp / 386 ft/tq
    Yes.
    bunch of them
    Single is fine- And, you can adjust that on the car as well, just not the overall length.
  1. suspension question
    By travz28 in forum Suspension and Handling
    Last Post: 04-21-2011, 12:10 PM
  2. Suspension question
    By DAGR$1 in forum Suspension and Handling
    Last Post: 09-24-2007, 06:09 AM
  3. Suspension Question
    By Richard Coy in forum Suspension and Handling
    Last Post: 06-12-2007, 11:12 AM
  4. Suspension question>>>>
    By chrombs13 in forum Suspension and Handling
    Last Post: 10-11-2006, 10:19 AM
  5. Suspension Question
    By WS6 SRT-8 in forum Suspension and Handling
    Last Post: 10-08-2006, 06:35 PM
