Thread: Suspension question>>>>
09-20-2006, 06:55 PM #1
- Sep 2006
- Laguna Beach, CA
Red; 58,000 org. miles- 1999 Camaro Z28, M6....
I just ordered an Eibach Spring Kit and Bilstein shocks for my 99' Z28 and I was just curious if there have to be adjustments made on the car when it is installed.......camber, etc. I have 19s on the car and I didn't get the kit that lowers it 2" or whatnot.....its only like 1.2" or a little more....Thanks for the help.
09-24-2006, 02:30 AM #2
- South of Heaven
Navy Blue Metallic (NBM)- 2002 Camaro SS
Revalved Bilsteins or stock HDs? You should get an alignment after the springs to put the car back in spec...
09-24-2006, 07:24 PM #3
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
im with him? the HDs wont hold up or dampen as well as a revalved set.
09-24-2006, 07:27 PM #4
- Sep 2006
- Central,Texas
Navy Blue Metallic- 2000 Camaro Z-28 SS
I recommend getting adjustable LCA's as well.
2000 SS #1827,NBM,A4,leather,t-tops,lid,eibach springs,hotchkis lca's,slp lid,slp cold air induction,slp loudmouth,baer brakes up front,13.11@107 on street tires,12.90@109 on dr's....time for the cam and intake to be installed
09-28-2006, 06:35 PM #5
when you raise/lower a vehicle, you must do an alignment. by raising/lowering a vehicle, it significantly changes the camber and toe.
here's where i did a spring swap on a 3rd gen car. http://fl-thirdgen.org/frontspringswap.html look at the very bottom. i took measurements before and after i swapped the springs out. major change after raising the car up about 2".
------------- BEFORE --- AFTER
CAMBER ----- L -0.48* --- L 0.48*
------------- R -0.20* -- R 0.60*
TOTAL TOE -- -0.16* ---- 0.47*Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
09-28-2006, 08:05 PM #6
- Aug 2003
- Honolulu HI
also, dont forget that you'll need an adjustable PHB to recenter your rear if you lower.
10-11-2006, 10:19 AM #7
- Sep 2006
- Florida
I have eibach 1.5 drop springs on my 02' z28 w/17's, I got LCA's and LCA relocators, as well as adjustable panhard rod. The rear with the eibachs and the stock equip. definatly didn't lanch as good as stock or with the new lca's. My bro, got the 2.0 drop w/18's and he did have camber problems in the front.
suspension question
By travz28 in forum Suspension and HandlingReplies: 6Last Post: 04-21-2011, 12:10 PM -
Suspension question
By DAGR$1 in forum Suspension and HandlingReplies: 1Last Post: 09-24-2007, 06:09 AM -
Suspension Question
By Richard Coy in forum Suspension and HandlingReplies: 5Last Post: 06-12-2007, 11:12 AM -
Suspension Question....
By Stankeric in forum Firebird / WS6Replies: 11Last Post: 11-16-2006, 02:40 AM -
Suspension Question
By WS6 SRT-8 in forum Suspension and HandlingReplies: 7Last Post: 10-08-2006, 06:35 PM
