    Junior Member WS6 SRT-8's Avatar
    Imperial MO.
    Light Pewter
    2000 WS-6 Trans Am
    Question Suspension Question
    I have a 2000 WS6 M6. It has Kenny Brown SFC's and springs. I'd like to get control arms, panhard bar, and torque arm. I can only afford one at a time. Which is most important? Should I get all adjustable? Can I use the factory hardware? Thanks for any advise!
    Member SSmoky01's Avatar
    Central,Texas
    2000 Camaro Z-28 SS
    What do you do most often? Auto X, drag race, or just plain fun on the street's. Either way you should get adjustable upgrades.
    2000 SS #1827,NBM,A4,leather,t-tops,lid,eibach springs,hotchkis lca's,slp lid,slp cold air induction,slp loudmouth,baer brakes up front,13.11@107 on street tires,12.90@109 on dr's....time for the cam and intake to be installed
    Imperial MO.
    Light Pewter
    2000 WS-6 Trans Am
    I hope to take it to the track for the first time Tuesday. I guess mostly fun on the street. I'm realy wanting ro build it to beat my buddy's 2005 Vette. Thanks.
    Member cobrahunter's Avatar
    South Bay
    1998 Camaro Z28
    The lower control arms and torque arm will help your tires connect to the ground. An after market panhard bar will be more sturdy than the stock stamped steel piece. However, if you plan on lowering the the car, an adjustable panhard bar will re-center the rear-end since lowering the car shifts the rear-end to the right.
    Imperial MO.
    Light Pewter
    2000 WS-6 Trans Am
    Thanks. Are they easy to install?
    Central,Texas
    2000 Camaro Z-28 SS
    Yes, very easy in my opinion. LCA's and torque arm, adjustable of course, will help you plant those tires will at the track.
    South of Heaven
    Navy Blue Metallic (NBM)
    2002 Camaro SS
    Actually the TA is what we did last, and only reason was to take stress off the tranny (not really necessary though) and adjust our pinion angle. We did our rear suspension LCA, APHR, then TA.
    Imperial MO.
    Light Pewter
    2000 WS-6 Trans Am
    Thanks Azrael. Looks like I need to find some more money to spend!
  1. suspension question
    By travz28 in forum Suspension and Handling
    Last Post: 04-21-2011, 12:10 PM
  2. Suspension question
    By DAGR$1 in forum Suspension and Handling
    Last Post: 09-24-2007, 06:09 AM
  3. Suspension Question
    By Richard Coy in forum Suspension and Handling
    Last Post: 06-12-2007, 11:12 AM
  4. Suspension Question....
    By Stankeric in forum Firebird / WS6
    Last Post: 11-16-2006, 02:40 AM
  5. Suspension question>>>>
    By chrombs13 in forum Suspension and Handling
    Last Post: 10-11-2006, 10:19 AM
