    Canby, Oregon
    1999 Camaro SS-M6 #1775
    This Doesnt Look Right...
    There is this Gap between my front fenders and my doors, i dont think the car has been in an accident.
    the gap on the right fender is a 1/2" bigger than the left gap.
    here are some pics? of the fender.....
    left- http://i64.photobucket.com/albums/h1...6/P9260050.jpg
    right- http://i64.photobucket.com/albums/h1...6/P9260051.jpg
    different angle..
    left- http://i64.photobucket.com/albums/h1...6/P9260048.jpg
    right- http://i64.photobucket.com/albums/h1...6/P9260049.jpg
    12.6 at 112
    2000pontiac6
    Guest
    Mines like that on my bird.... the part of the fender that connects there is bent the opposite way... i tried bending mine back but it was already cracking bad i didnt too much and it helped some but now is back to how it was... i dont understand how this even happens but the one on the other side of my car is actually broken off by where it attaches.
    hope that made sense. just look under your car and hopefully you'll see what i mean just be careful if u try bending it back
    LA
    Grey
    2010 Camaro 2SS/RS CGM
    unbolt your fender and see if the bracket is broken that connects it to the car, eithor that or check the bolts under your car where it connects to the bottom underneith. one of them might have broken or has come loose. Otherwise youll have to buy new fenders and bolt them up.
    Santee, CA
    This is a very common occurrence when these cars are jacked up in the wrong location. Yours is about the worst case of this I have ever seen.
    Your car can be fixed to eliminate the gaps.
    At the bottom of your front fenders, you should normally see a flange and 2 bolt heads. These fender flanges should point straight down, or perpendicular to, the ground. My guess is that yours definitely do not. A lot of people, and auto mechanics, assume that this flange is where the car should be jacked from - it is not. In fact, there is text somewhere around that area that reads something similar to: "Warning - Do Not Jack"
    Your fender bottoms bolt to a metal backing flange, which is attached to the chassis. You, or a body shop, should be able to carefully bend these flanges back to their normal position.
    Good luck, and let us know what happens.
    Vance Chula
    1996 Camaro Z28 SS #1688
    2010 Camaro 2LT RS
    http://www.cardomain.com/id/vchula
    Canby, Oregon
    Quote Originally Posted by VChula View Post
    Thanks! that info is Very Helpful I'll let you know what happens!
    Junior Member 1SICZ's Avatar
    2002 35th Ann Z28
    What VChula said.....sounds like someone jacked in the wrong spot...
    John
    Too many mods too list......
    Canada eh
    99 TA
    my pass side looks like that too... ive heard you can whack it back into place underneath with a 2x4 and a hammer, but i am too much of a pussy to try it, in case it breaks something or makes it worse
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    Yeah, take a good look under your fenders.. most of the cars around here that I've seen suffer from the bad jack/lift placement... under the doors is a bad place for crunches as well... with all the money we spend at those shops.. you'd think they would know.. or atleast fix what they screw up!
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    Feb 2006
    S.C
    1999 Camaro
    Im on my second camaro and ive had this problem on both of them. When I took my car to the body shop to get painted they just tightened them up for me
    Canby, Oregon
    YES!!!! I went out there and did my best to get it fixed and pulled back in. I got the left one to go back perfectly but the right one still sticks out just a hair
    Left fender: http://i64.photobucket.com/albums/h1...enderfixed.jpg
    Right fender:
    Underneath:
    http://i64.photobucket.com/albums/h1.../DONOTJACK.jpg
    2002 35th Ann Z28
    looks alot better than it did....
    John
    Feb 2006
    P.A.
    98 ss
    Yea the same thing happened to my car. I fixed it pretty easily just take 2x4 or a piece of wood that covers the flange that comes down where the two bolts are. Then take a hammer and lightly tap it back into place.
  1. air lid doesnt fit.
    By redtaws6 in forum General Help
    Last Post: 07-01-2012, 04:18 PM
  2. Why doesnt this guy like T/A's?
    By 01ws6er in forum Firebird / WS6
    Last Post: 01-31-2009, 02:54 PM
  3. Doesnt it seem like just yesterday??
    By Ryans99LS1 in forum Firebird / WS6
    Last Post: 10-19-2008, 07:42 AM
  4. new hood doesnt fit i need help
    By screaminbird in forum Firebird / WS6
    Last Post: 09-13-2008, 05:56 PM
  5. doesnt want to idle
    By tcamaro98 in forum General Help
    Last Post: 07-26-2008, 12:55 PM
