Thread: air lid doesnt fit.
06-26-2012, 06:02 AM #1Junior Member
- Jun 2012
- Carlos
red- 2000 Pontaic Trans am ws6
air lid doesnt fit.
I have a 2000 pontiac trans am ws6. I just installed a tb, below, mafsensor,and slp air lid.
When i go to lock it in place it doesnt fit in the slots and hangs over the front of where it should be seated abnout a half inch.
i need to know if any else has had this problem. Also what i need to do to fix it.
06-26-2012, 06:30 AM #2Spaz is My Mentor
look at this thread below:
http://www.ls1.com/forums/f6/correct...s-down-152522/
post 14 has the correct way the air lid should be seated in the tray.
06-30-2012, 08:37 PM #3Junior Member
- MA
Black- 2002 WS6
Some suggestions: Are the tabs on the back of the lid seated tightly? Are the new TB and bellows seated back enough for the lid to slide back into place and line up?
07-01-2012, 07:48 AM #4Senior Member
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
It may be your bellow I had to cut mine for the lid to slide back far enough..also make sure the bellow is notched for the tb and maf you will see the tabs on them...a 3" air cut off tool works great, jut cut a little at a time until it fits
07-01-2012, 04:18 PM #5
if you bought a stright bellow( not corrugated like the factory one) then you might have to cut it to fit like it was mentioned. I will disconnect the the bellow and install the lid correctly. Then put the bellow next to the MAF and TB and compare. If it looks like it is too long then thats the problem. Just cut as necessary.
Why doesnt this guy like T/A's?
By 01ws6er in forum Firebird / WS6Replies: 8Last Post: 01-31-2009, 02:54 PM -
Doesnt it seem like just yesterday??
By Ryans99LS1 in forum Firebird / WS6Replies: 21Last Post: 10-19-2008, 07:42 AM -
new hood doesnt fit i need help
By screaminbird in forum Firebird / WS6Replies: 2Last Post: 09-13-2008, 05:56 PM -
doesnt want to idle
By tcamaro98 in forum General HelpReplies: 14Last Post: 07-26-2008, 12:55 PM -
This Doesnt Look Right...
By Tyler_LS1 in forum Appearance SectionReplies: 11Last Post: 10-01-2006, 10:45 AM
