Results 1 to 15 of 15
Thread: doesnt want to idle
07-25-2008, 05:28 PM #1Junior Member
- Feb 2008
- Washington
silver- 2002 Camaro
doesnt want to idle
hey guys im new hear and need some help. i recently installed TSP 5.3l heads with a MS3 and got there tune for it. it runs great for a while but when i make some hard pulls in it and start to slow back down for a light it wants to die the rpms drop to 500 and then go back to 1500 and it will keep doing this until i take off again. and i get a P0106 code. i switched out the MAF back to stock. i drilled the throttle body blade. i cant figure this thing out i need help fast i gotta go back to work
07-25-2008, 06:33 PM #2
what do you mean you drilled the TB blade?
07-25-2008, 06:37 PM #3
07-25-2008, 07:12 PM #4Junior Member
- Feb 2008
- Washington
silver- 2002 Camaro
the blade on the throttle body i drilled a little bit bigger hole to let more air in and i tried spraying the vacum lines with starting fluid to find the leak but i couldnt find one
07-25-2008, 07:19 PM #5
07-25-2008, 07:30 PM #6Junior Member
- Feb 2008
- Washington
silver- 2002 Camaro
it still runs the same as it did before i did it it only does it after some hard pulls and then i gotta slow down
07-25-2008, 08:07 PM #7O U 8 1 2
- Nov 1999
- over here...
i dunno... maybe your alternator is taking a shit... what kind of head gaskets did you use??? and what kind for the intake manifold???
07-25-2008, 08:31 PM #8Junior Member
- Feb 2008
- Washington
silver- 2002 Camaro
i think the head gaskets are graphite and the intake manifold are the stock ones jus reused them
07-25-2008, 11:46 PM #9Junior Member
- Feb 2008
- Washington
silver- 2002 Camaro
anyone else have any suggestions please help
07-26-2008, 02:05 AM #10Impounded
- Oct 2007
- Beaver Dam KY
The code is for a vacuum leak. I say after the romps it might have sprung an air leak somewhere. The TB needs to be replaced IMO after drilling it. I have had this issue and it was caused by a weak battery that wouldnt hold a charge. Check for a vacuum leak, maybe it could be something as small as the PCV or the brake booster...The TB needs to be replaced next.
07-26-2008, 06:55 AM #11
07-26-2008, 10:28 AM #12Junior Member
- Feb 2008
- Washington
silver- 2002 Camaro
thanks for the help any suggestions on how to check for a vacuum leak i tried spraying starting fluid around the intake manifold i have everything capped off.
07-26-2008, 11:56 AM #13
I'll add my 2 cents.
p106 is a map sensor code. Now whether it's being thrown due to a bad map sensor or because of the severe surging I don't know. Go to gearchatter.com and look at the dtc description for 106.
What tune exactly do you have in there? I would probably bet that it's a tune issue. That's a fairly large cam so the tune would be very important.
07-26-2008, 01:49 PM #14Junior Member
- Feb 2008
- Washington
silver- 2002 Camaro
the tune is whatever texas speed made it from there mail order tuning it only does this after i make hard pulls then slow down to a stop
07-26-2008, 01:55 PM #15
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 04:36 AM -
air lid doesnt fit.
By redtaws6 in forum General HelpReplies: 4Last Post: 07-01-2012, 05:18 PM -
Help: intermittant rough idle, off idle hesitation
By Matto4785 in forum General HelpReplies: 1Last Post: 09-21-2009, 06:12 AM -
Why doesnt this guy like T/A's?
By 01ws6er in forum Firebird / WS6Replies: 8Last Post: 01-31-2009, 03:54 PM -
This Doesnt Look Right...
By Tyler_LS1 in forum Appearance SectionReplies: 11Last Post: 10-01-2006, 11:45 AM
bad idea... you need to get another TB... the ectra air coming in is probably throwing off your AF ratio... you are probably stuck in "limp home mode"...
