Results 1 to 13 of 13
    California
    My battery gauge is jumping around
    Its seems that @ idle the the car is fine, when I'm driving the volts will drop under 13 on the gauge and my headlights will dim and my check gauges light will come on. Then it will go up back to normal for a moment and drop back. Is it the alternator? maybe a loose wire somewhere. I changed the battery about 6mo ago. Any suggestions of what it might be would be appreciated
    My money is on the alternator. There's a couple of ways to test it. The easiest is to use a multimeter set on dc volts and check across the battery terminals with the car running. You should see ~14.4 volts with the car running. The other way is to start the car and turn on the headlights and disconnect the battery. If the car dies then your alternator is shot.
    Aug 2000
    Indy
    That was an old school method but is that safe for newer cars, I heard you can F something up by doing that. ??
    ky
    99 camaro
    I work on cars for a living, yes you will F somthing up like your ECU for starters. What Danger731 is saying is very true, that is the old school way. The easy way would be take your car to a shop or even a parts house that will check your charging system for you. That is the best way to find out what is going on. just my .02 cents. Good luck
    1 BAD ASS BOWTIE StangKiller615's Avatar
    Feb 2006
    Nashville Tn
    Black on Black
    Defiently sounds as if your alternator is on its way out.
    Bragg NC
    Met. Sunset Orange
    01 SS
    If you take your car too say chinazone they will check your chargin system for free. Get a multimeter like said above and see how many volts its holding while running. Check your batt terminals for corrosion and make sure there tight.
    Are you saying it runs low or just drops down once and a while? Mine drops when im at idle and the fans first kick on but then raises again.
    J
    Quote Originally Posted by camky99 View Post
    That's the first I've ever heard of that. Not that I'm doubting you guys. I've just never heard of that being a problem before. I normally use a meter to test but have pulled the cable in a pinch many times before without any problems. Guess I'll stop doing that.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    you can cause a short and burn up one of the wires as well as fry a board in the ECU. There is a grounding srap in back of the alternator, check for looseness. Check all your grounding wires as well
    Member SR71's Avatar
    Irving, TX
    1998 Trans Am, 2007 TB SS
    Sounds like an alternator to me. Just had to replace mine. This summer has been a lot hotter than recent years, and I'm pretty sure that, along with my sound system probably took mine out. Just get a voltmeter, turn on your call and all the accessories at the same time, and make sure it doesn't drop below 13volts. Depending on the "draw" of everything, it may dip and come back up, which is normal. But...If the volts keep dropping and don't hold, it's the alternator. Mine dipped as low as 11.6 and was still falling when I tested mine. Hope this helps.
    California
    My car died today, the volts went down to 8 and continued to decline until it ate sh--. It sounds to me that the alternator isn't doing it's job which is alternate power back to the battery.
    Would most of you agree.
    Member BlackZ28629's Avatar
    memphis
    99 Z28
    ALTERNATOR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Go to Auto Zone IF you just have to check it out; they'll do it for free.
    OTherwise, change the alternator out; that is your problem.
    Irving, TX
    Definately the alternator.
    California
    It was the alternator, I fix, it work, I like.
    Thanks for your help guys
  1. temp and gas gauge keep jumping around
    By k-hobbs-ws6 in forum General Help
    Last Post: 11-28-2012, 06:21 AM
  2. Question: battery gauge
    By reaper ws6 in forum General Help
    Last Post: 11-01-2011, 11:54 AM
  3. battery/alternator gauge...
    By bolden3 in forum General Help
    Last Post: 08-31-2007, 08:21 PM
  4. Battery Gauge
    By Choppers in forum Stereo and Electronics
    Last Post: 01-29-2007, 07:20 AM
  5. Oil Pressure Gauge Jumping?
    By bwinch in forum Internal Engine
    Last Post: 10-27-2006, 01:47 PM
