Results 1 to 13 of 13
Thread: battery/alternator gauge...
08-29-2007, 02:32 PM #1
does any one know why under acceleration my gauge jitters between 14 and 15 volts?
08-29-2007, 03:00 PM #2
08-29-2007, 06:02 PM #3
08-29-2007, 06:18 PM #4Impounded
- Nov 2005
- Dallas, TX
Pewter- 2000 Firehawk #506 A4
I notice mine hovers around 13 when i'm cruising with the a/c on. Sometimes at red lights it'll drop right to the edge of the yellow, but them move back up to 13 when i start moving. it's only at 14 for about 5 minutes when i first start it. Is this a sign it may be going out?
08-30-2007, 08:54 AM #5
08-30-2007, 09:01 AM #6Impounded
- Nov 2005
- Dallas, TX
Ok? If you disconnect the battery on a car after it's been started, it will keep running off the alternator. I don't care if you want to call that power A/C or D/C, but it's usually around 14 volts and mine is typically at 13 and sometimes into the 12's under load from the air conditioner and fans. Is this a sign of the alternator starting to go out?
08-30-2007, 12:52 PM #7
08-30-2007, 12:53 PM #8Impounded
- Nov 2005
- Dallas, TX
My LT1 Camaro was always at 14, so that's why I was wondering if this is normal for LS1's or something?
08-30-2007, 12:57 PM #9
I guess with A/C on (with fan on max), headlights, radio, and then you come to a stop (brake lights) and then if it's just above the yellow, it's probably all good.
The way I'll know for sure if the alternator is bad is if I go the start it and the battery is dead...so far so good, but I would feel a lot better if the gauge read higher under full load.
I guess we would need a higher output alternator for that.
08-30-2007, 01:56 PM #10Impounded
- Nov 2005
- Dallas, TX
Yeah. Every car I've owned has had the alternator go out. Luckily it's not too expensive and I can do it myself. If it does go out, I'll just get a heavy duty one.
08-30-2007, 01:58 PM #11
08-31-2007, 07:14 PM #12
08-31-2007, 08:21 PM #13
Battery / Alternator Problem
By cpw006 in forum General HelpReplies: 9Last Post: 04-05-2010, 09:23 PM -
Alternator bad? or battery? or ground?
By 96z28 in forum General HelpReplies: 11Last Post: 08-21-2008, 02:01 AM -
alternator not charging battery...HELP
By Unfrozn in forum External EngineReplies: 4Last Post: 11-05-2007, 06:32 PM -
alternator..now battery?
By blackhawk01 in forum External EngineReplies: 7Last Post: 10-23-2007, 06:06 PM -
alternator vs. battery charger
By ss~zoso~ss in forum General HelpReplies: 9Last Post: 03-08-2006, 05:25 PM
