Results 1 to 20 of 37
    Apr 2011
    missouri
    red with black strips
    2000 trans am ws6
    temp and gas gauge keep jumping around
    My temp and gas gauge keep jumping around once and a while any ideas y
    Wisconsin
    2001 Camaro SS M6
    Quote Originally Posted by k-hobbs-ws6 View Post
    If it was one of the gauges I would say a faulty sensor but since the odds of you having problems with both........I would say some type of electrical problem. Whether its a faulty wire or ground, more then likely it is something along those lines. Thats just my .02, Cutlass is the "Man" with issues like this and will more then likely chime in and give his professional opinion
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    Centerville OH
    blue
    1999 TransAm
    when you say they "jump around", ...what kinda magnitude are you talking about? for instance my fuel guage will dance a little bit mainly when it's cold outside, or from a cold start. but it's maybe like an oscillation of about 1/16-1/8 inch on the dial or so... my temp guage seems highly "damped", meaning it just sort of rises slowly from cold start, don't see any oscillations in it at all..
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Here I am.
    OP...need more info like wileyCoyote said.
    Are we talking big fast jumping around or what?
    Apr 2011
    missouri
    2000 trans am ws6
    Like sometimes twitching around a Lil bit and sometime jumping like a quarter inch
    Madison, WI
    2001 Silverado Z71
    Well you might have bad instrument cluster. I can't find much else in common between the temp and fuel gauge.
    Apr 2011
    missouri
    2000 trans am ws6
    Yea some one else told me Tht to. But if I get a new one will my car still read the same on the odometer
    Madison, WI
    2001 Silverado Z71
    If you get a unit through a GM dealer, the rebuilder will set the odometer mileage to your current mileage. If you buy a used one, then it'll read whatever that car had.
    But you might be able to send your used one to an authorized dealer and have them set the odometer.
    Apr 2011
    missouri
    2000 trans am ws6
    What could happen if I don't get a new instrument cluster
    Wisconsin
    2001 Camaro SS M6
    It could totally take a shit (IE Nothing working on it)
    Pittsburgh
    2008 Hummer H3
    Most times the cluster has to work for things like state inspections, and to submit the vehicles mileage to insure it, and so forth..
    Just my .02
    Apr 2011
    missouri
    2000 trans am ws6
    How much is a new one
    Madison, WI
    2001 Silverado Z71
    Its not a commonly replaced item so you will have to find out the cost on your own.
    Junior Member ntymd8r's Avatar
    Corona, CA
    2001 Chevrolet Camaro Z28
    I got a problem woth my fuel gauge, too. The gauge will read full at every fill up, but more times than not, it will slowly go up and down. It sometimes goes all the way down past empty for a few seconds/minutes. Any ideas as to what is causing this?
    2001 Chevrolet Camaro Z28, M6, Eibach Pro-kit, BMR STB, BMR Adj-PHB, BMR RB's, BMR SB's, BMR Adj-TA, KYB Adj-shocks, K&N, SLP LM, SLP Y-Pipe, SLP Intake, Predator Custom Tuned...
    Treat her well and she'll put a smile on your face every time you get on her!
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Does the needle fluctuate while going through a turn?
    Corona, CA
    No. I thought of the fuel in the tank having an effect on the gauge. Going up and down hills, and left and right turns have no effect. It will flucuate any time and under any driving condition....
    North Jersey
    2004 GTO M6
    Sounds like the beginning of a failing cluster.
    Houston, Texas
    2000 C5 Torch Red
    For the first issue i had something similar in my Silverado and theres a Speedo guy out of Florida you can mail to and he'll fix the cluster.
    Second issue with just gas gauge sounded like my failing fuel sending unit.
    Corona, CA
    How would I test the fuel gauge to see?
    Corona, CA
    Is there a way to test the sending unit?
  1. Want to trade Tranny Temp gauge for Oil pressure gauge.
    By jrbonds in forum Parts Wanted / Trade
    Last Post: 07-29-2011, 08:47 AM
  2. Hooking up Oil pressure gauge,and Temp Gauge
    By BirdFlewLS1 in forum General Help
    Last Post: 01-15-2008, 06:15 AM
  3. Oil Pressure Gauge Jumping?
    By bwinch in forum Internal Engine
    Last Post: 10-27-2006, 01:47 PM
  4. My battery gauge is jumping around
    By cmaross01 in forum General Help
    Last Post: 09-08-2006, 04:25 AM
