Thread: battery gauge
    REAPER Z28 reaper ws6's Avatar
    Apr 2009
    Tyler TX
    Navy Blue Metallic/Black
    02 camaro z28/01 wife t/a
    battery gauge
    It's is normal for my battery pressure gauge to be almost at the full pressure mark by the red mark?
    also my lights pulse on and off and my pressure gauge is always pulsing as well not a lot like they dont complety turn off, they just dim and then get really bright then dim again and get really bright, this happen's wen my battery gauge is almost at the full position. What could be causing this problem's? the battery, alternator, and starter are all new
    pls help
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Sounds like your alt is overcharging the electrical system. You'll have to take out the alternator and take it to the parts store to be tested.
    Apr 2009
    Tyler TX
    ok will do. Thanks
    The gauge measures voltage, not pressure. Although it is a 12 volt system, a properly functioning charging system will generally have an output in the range of 13.8 to 14.4 volts. New components do not always equate to working components. Check your connections, looking carefully for evidence of corrosion or electrical arcing, and if all looks good then get it to a shop that can load test the battery and charging system if you do not have the tools to do so.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Is your alternator is re-manufactured?
    If hooked up properly, that's probably 99% of your problem. You should have a warranty with it as well, I'd take it to get it tested, but if they say it's good, return it and try another one. It's the way of remanned world, they polish a turd and sell it.
    Member blackcar's Avatar
    Arkansas
    '02 Z28 parting-out
    There is a little wire on the bottom of the alt. that is known for getting broke. If it was broke would it cause this problem??
    Apr 2009
    Tyler TX
    yeah that's what im going to do with it, thanks for the help. (Man you got to love f-body's if is not one thing is another lol)
    01 z/28, M-6, Heads, Cam, Intake, Block, Full Exhaust, Suspension work, Gears, Clutch, and tune - 430HP & 390TQ
    01 T/A A-4, Lid, free mod's, shorty headers, Slp exhaust, msd wires
  1. Battery trade in dfw My Optima for your battery
    By Lucky 13 in forum Parts For Sale / Trade
    Last Post: 04-10-2009, 03:33 AM
  2. battery/alternator gauge...
    By bolden3 in forum General Help
    Last Post: 08-31-2007, 08:21 PM
  3. Battery Gauge
    By Choppers in forum Stereo and Electronics
    Last Post: 01-29-2007, 07:20 AM
  4. Battery disconnect=inop coolant gauge?
    By shortdog in forum General Help
    Last Post: 11-25-2006, 05:26 PM
  5. My battery gauge is jumping around
    By cmaross01 in forum General Help
    Last Post: 09-08-2006, 04:25 AM
