    Another Slow LS1 shortdog's Avatar
    St. Louis, MO
    99 Z28 A4
    Battery disconnect=inop coolant gauge?
    I noticed the last several times I r&i'd my battery, my coolant gauge was inoperative temporarily for about 15-20 minutes. Is this normal? My rebuilt motor is going in soon and I can't diagnose an overheating problem if the gauge isn't working.
    Retired Outlaw Sum Bitch
    Disconnecting the battery should have no effect on your gauge. Intermittent gauge tells me there is an issue with either the sending unit/wiring/gauge itself.
    St. Louis, MO
    99 Z28 A4
    Possibly, but it's fine any other time. It's only inop temporarily when I completely disconnect the battery to get it charged/replaced. If it was my coolant sensor, I would think the gauge won't operate at all.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Gotta agree with Sarge on this one, it's going to be an electrical glich. Of course it could be the wiring or the gauge, but we had a similar problem with a late model GM car in the shop a couple days ago. Long story short we observed the gauge reading stuff that wasn't actually going on with the motor. Finally the gauge reading dropped down to nothing while the engine was fully warmed up. Because of the difficulty of getting to the sending unit to check it, we figured let's just replace it and see what happens. It fixed the problem. Based on what I saw this sending unit do on that car (that didn't make alot of sense) I'd suggest trying that first. And yes -it can be an intermittent problem.
    St. Louis, MO
    99 Z28 A4
    When you say sending unit, are you talking about the coolant temp sensor on the head? If not, then where is the sending unit located? Appreciate the help.
    Yes....the sending unit screwed into the head....I'd run a wire from there outside the car to the guage....and test it like that before I ran/routed a new wire through the firewall and such.....
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    True-that would check the wiring. I would just replace the sending unit and see what happens, it's an educated guess. By the time you get access to the back of the dash/gauge on some of these cars you might as well have replaced the gauge, same with the sending unit (on some cars). Realize this sounds sort of shade tree but in the commercial shop you have time limits and way too much to deal with to do things in a more scientific manner (most of the time). So you go with things that work from past experience; it's not a huge investment to get a sending unit, and could be "job done and back to fun".
  1. Question: battery gauge
    By reaper ws6 in forum General Help
    Last Post: 11-01-2011, 11:54 AM
  2. lid install/battery disconnect/stereo code
    By wvsp518 in forum General Help
    Last Post: 06-14-2008, 06:00 PM
  3. Battery Gauge
    By Choppers in forum Stereo and Electronics
    Last Post: 01-29-2007, 07:20 AM
  4. WTB battery tray/coolant tank 95 Camaro
    By retriever in forum Parts Wanted / Trade
    Last Post: 12-27-2006, 11:13 AM
  5. I can't disconnect the battery terminal!?!?!?!
    By johntm86 in forum Firebird / WS6
    Last Post: 05-06-2006, 08:28 PM
