    Aug 2006
    michigan
    Cozumel Blue
    99 Firebird
    Exclamation Engine misfires, rough idle, minor hessitation upon acceleration
    My '99 Firebird V6 3.8 ran excellent up to about 6 months ago when it started throwing service engine lights for P1441 emmissions code, replacement of the gas cap made the light go off. The code came back, has stumped 3 dealerships and 4 race shop mechanics.
    Engine hessitates to start, gas smell intense, black smoke from exhaust at startup, idles intensely rough for 2 seconds, then switches over to a somewhat smoother idle with what appear to be skips or misfires.
    Plugs and wires had been replaced, car received complete fuel injector and engine enema. No change. Does not accelerate very smoothly.
    Considered a fuel pressure regulator replacement, I believe it may be related to some sensor miscommunicating to the computer. Computer was recently reflashed following Cat replacement. My 2nd '99 Firebird V6 3.8 does not have any such problems after a plug and wire change, new Cat and reflash. Yes, the plugs and wires were stock replacements and "professionally installed by a certified Michigan Mechanic".
    All mechanics have been stumped and I'm out $500.00...
    Also how does one replace a multifunction switch that has a ghost short that knocks out the 15amp A/C and Cruise control?
    GM does not list a picture of the replacement part, and it is not a stock item. Aside from that the dealership claims after diagnostic there is only an 80% chance replacing the switch will resolve the shorting issue
    Junior Member murray01's Avatar
    Arkansas
    01 z28
    My neighbor had a problem like this on his v6 and it was a coil that was bad. Not saying that this is your problem but it may be something to check into. They are fairly easy to remove and autozone will check them for free.
    South of Heaven
    Navy Blue Metallic (NBM)
    2002 Camaro SS
    Emissions codes and running rough? Sounds like my first guess would be an O2 sensor going bad.
    Member matthewaqui's Avatar
    Lakewood, California
    Red/Silver/Black/Red
    TA-G8-Expe-L200-Camaro
    Rough Idling!
    Pm experiencing the same problem... where you ever able to resolve this problem?
    Matt
    Quote Originally Posted by skintox View Post
  1. Help: rough acceleration
    By L...S...1 in forum General Help
    Last Post: 12-15-2009, 07:48 PM
  2. Help: intermittant rough idle, off idle hesitation
    By Matto4785 in forum General Help
    Last Post: 09-21-2009, 05:12 AM
  3. Help: 2000 Camaro misfires during acceleration
    By JFos in forum General Help
    Last Post: 05-12-2009, 09:20 PM
  4. Help: Bad Flow - Rough Acceleration
    By matthewaqui in forum General Help
    Last Post: 03-05-2008, 02:22 PM
  5. Misfires when engine warms up... help!!!
    By Shnukemz in forum LT1
    Last Post: 10-05-2006, 03:27 PM
