Thread: Bad Flow - Rough Acceleration
03-02-2008, 06:17 PM #1Member
- Jul 2007
- Lakewood, California
Red/Silver/Black/Red- TA-G8-Expe-L200-Camaro
Hello F-bodies,
I read quite a few post in this forum regarding the Catalyst Converter and P430 Code. I have the following codes:
P0119 Generic
IAT Sensor 1 Circuit
High Input
P430 Generic
Catalyst Efficiency
Below Threshold
(Bank 2)
P430 Generic PD
Catalyst Efficiency
Below Threshold
(Bank 2)
I have a 2000 Silver Trans Am with 120,700 miles on it. I was hoping that I could keep the vehicle running until next year and upgrade to a 2010 Camaro. Just today I'm experiencing very rough performance on my TA, typically upon startup. When I accelerate, the vehicle slugs and does not fire..... there is very rough idling of sort. This complication was very evident today for it took awhile for the vehicle to get out of this poor performance stage.
Once the vehicle gets through the sluggish torment, acceleration is alright.
This problems reminds me of when I forgot to plug in my right side coil wires in after replacing the plugs.
Would a bad Catalytic Converter cause a back flow and choke ignition causing no acceleration and very rough idle?
Any suggestions would be greatly appreciative.
Matthew
03-03-2008, 09:02 PM #2Impounded
- Oct 2007
- Beaver Dam KY
Bad Cats can cause a lot of problems... If you have to have them get new ones(emissions bullcrap).. if not.. get rid of them and turn the code off(via a tune). and your IAT sensor probably just needs to be replaced... Simply fix..
03-04-2008, 06:46 AM #3Member
- Jul 2007
Probably Correct.....
Thanks for the word Josh...... as I was idling in drive..... I seem to here a low rattle from beneath, thinking the Driver side cat is bad inside. I'm in California and will need those Cats.... thanks for the advice buddy.
I have heard other experiencing the acceleration stumble that I have had, though there has been no advice posted...
Matt
03-04-2008, 10:01 AM #4Member
- Jul 2007
Service is Underway
Well Josh,
I called GM and they will replace the cats for me at no charge. I'm over the 120,000 miles warranty at 120,800 but explained I bought the vehicle used 110,000.
I think that is the problem of some backflow restrictions causing all sort of bad performance.
Once again, thanks man!
Matthew
03-04-2008, 10:54 AM #5Impounded
- Oct 2007
- Beaver Dam KY
Cool. If the dealer will do it for free that is always the way to go.
03-05-2008, 09:07 AM #6
03-05-2008, 01:43 PM #7Junior Member
- Dec 2007
- South Carolina
Red- 2002 Transam WS6
I drive the M6 and have same problem except for I have no cats anyway. I was always wondering about this. Most of the time mine happens is after a really rough storm and it gets wet underneath. Strange to me.
03-05-2008, 02:22 PM #8Member
- Jul 2007
Other Diagnose.
You luckout on this thread......... I have been advise to replace the IAT, the ECT and PCV Valve. That could possibly be our problem. The replacement to these parts are not very expensive.
Check these threads out to get a better understanding...... we seem to experience similar problems:
http://www.ls1.com/forums/showthread.php?t=79616
http://www.ls1.com/forums/showthread.php?t=70618
Diamond in the rough -- really rough.
By pajeff02 in forum Classic MuscleReplies: 24Last Post: 02-03-2011, 08:12 AM -
Help: rough acceleration
By L...S...1 in forum General HelpReplies: 22Last Post: 12-15-2009, 07:48 PM -
Engine misfires, rough idle, minor hessitation upon acceleration
By skintox in forum Internal EngineReplies: 3Last Post: 03-02-2008, 06:23 PM -
High-Flow Mass Air Flow Sensors
By 2001bird in forum External EngineReplies: 7Last Post: 11-10-2006, 09:02 PM -
Engine runs rough, idles rough, runs rich
By skintox in forum General HelpReplies: 2Last Post: 08-22-2006, 03:31 PM
