Results 1 to 20 of 23
    Member L...S...1's Avatar
    Jul 2009
    NOR*CAL
    2000 SS
    rough acceleration
    whats up guys..........so about a month ago i put some of the Chevron fuel injection cleaner stuff in my gas tank. i thought it would help but im not sure if it did. i always put medium grade fuel i think its number 89 and i think this just started after i put that chevron fuel injection cleaner in. ill try to explain it........ i got a 2000 ss M6 BTW. so when i press the gas it kinda hesitates and whenever i push the clutch in to shift it kinda boggs down. is there any fuel injection cleaner that actually works or what could this be?? and when i got the car it wasnt like this. i could just tap the accelerator and it would take off.
    Factory Freak Mikat1's Avatar
    Sep 2009
    Upper California
    Artic
    2002 Z28
    might wanna change your fuel filter.. mine was doing the same thing, changed the filter.. smooth as silk
    2002 Z28 Slighty modded...
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Fuel filter like above said and I would also clean your MAF.
    Coral Springs, Fl
    Sunset Orange Metalic
    Quote Originally Posted by Mikat1 View Post
    +1 on both
    Coral Springs, Fl
    BTW to clean the maf use maf cleaner
    just in case you didn't know
    Member TA98's Avatar
    Mar 2009
    Maryland
    WITH 4-10 PROVEN HP AT THE WHEELS!!!!
    where did you guy purchase a fuel filter for your car? i work at advance auto and when i look it up it list purolator with no part number and says part not servicable.
    Coral Springs, Fl
    Thats the stuff
    Coral Springs, Fl
    Quote Originally Posted by T/A98 View Post
    try autozone, advance sucks
    Jul 2009
    NOR*CAL
    2000 SS
    ok thanks, im looking forward to the extra horsepower haha im still a noob but where is the fuel filter located? or is there a post on here how to change it out?? thanks
    Coral Springs, Fl
    if you crawl under the car the fuel filter is located in between the driver door and left rear tire. Get under there and you will see fuel lines and the filter there. New one is like 10-15 dollars new.
    Jul 2009
    NOR*CAL
    2000 SS
    ok so just go under, look for it, take it off and put a new one on? is that it?
    Coral Springs, Fl
    Quote Originally Posted by L...S...1 View Post
    Well, you have to make sure the pressure is relieved from the line first. I do this after the car has been sitting for a while. go under the hood and on the fuel line there should be a valve to release the pressure, unscrew the cap and its like a tire valve stem, hold a rag there in case gas starts spewing. Once there is no pressure i think its a nut that screws onto the fuel line on one side of the filter and a clip on the other side.
    And make sure when you take the filter out you have a little bucket with you as a little gas will probably come out of the filter and lines.
    Let me know if you have any problems. Its honestly a real easy project.
    Coral Springs, Fl
    I was just going to post that. I thought it was on the ls1howto though.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    I can't seem to find it now but on install university they added injector cleaner and there plugs got a red coating. You might take out a plug and check it out.
    Coral Springs, Fl
    Didn't think about that
    never was too crazy about all that injector cleaner/octane booster over the counter crap
    Bay Area
    my highbeams
    I gave up looking but I saw it
    Jul 2009
    NOR*CAL
    2000 SS
    ok i probably wont do it til thursday, thats my next day off. on that install link it says to disconnect the battery, is that neccesary? and to take the fuel fuse out? and just one more question. does the gas tank have to be on E to do this? or does it matter. and i just saw that big thread about fuel filters, and it seems you cant go wrong with replacing the fuel filter.
    Bay Area
    my highbeams
    For the filter? Just remove the schrader valve, take off the gas cap and go for it-you will get some gas just work through it.
  1. Diamond in the rough -- really rough.
    By pajeff02 in forum Classic Muscle
    Last Post: 02-03-2011, 08:12 AM
  2. Help: Bad Flow - Rough Acceleration
    By matthewaqui in forum General Help
    Last Post: 03-05-2008, 02:22 PM
  3. Replies: 3
    Last Post: 03-02-2008, 06:23 PM
  4. acceleration at WOT
    By totalkos in forum General Help
    Last Post: 11-25-2007, 12:01 PM
  5. Engine runs rough, idles rough, runs rich
    By skintox in forum General Help
    Last Post: 08-22-2006, 03:31 PM
