Results 1 to 3 of 3
08-22-2006, 06:53 AM #1Junior Member
- Aug 2006
- michigan
Cozumel Blue- 99 Firebird
Engine runs rough, idles rough, runs rich
I was looking at replacing my fuel pressure regulator to remedy issues that stump every mechanic to date. No codes thrown. Plugs and wires changed. Rough starts, rough idles, black smoke, minor hesitation / misfires during acceleration....just had $100 enema to cleanse the engine...didn't help.
3.8L V6 99 Firebird (wants to be an LS1 someday).
Injectors are cleaned. Can this be affiliated with a short to the multi function steering stalk switch that occassionally decides to billow white electrical smoke up the Steering column?
Vehicle used to run excellent, then threw code P1441 emmissions which went away with replacing gas cap. Dealerships and private mechanics all stumped, and my wallet is getting thinner by the day seeking a remedy.
Someone said check vacuum line from intake to fuel regulator?
Another person asked if PCM reflashed after cat replacement...YES!
Who likes challenges out there?
08-22-2006, 07:08 AM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
This is posted in the wrong section and I'm sure a mod will move it for you....then you'll get some replies....turn your internet filters on high as you solicited a crap shoot....let me take a swipe at it though while I'm on here....
You have probably mutiple problems....If I understand your post ....dealerships/mechanics have all diagnosed/troubleshot this thing....the normal approach was to eliminate fuel pressure/air fuel/ignition/etc and all of these system report normal ops ( I assume)....
From what you described and with the assumption all the above mentioned obvious systems have been checked and cleared...I would suspect valves...sounds like you have a compression/valve issue. Have "them" check your compression...valves.....
As for the smoke coming out of your steering column...I would "guess' that is a dead ass short and it burns the insulation of the shorted wire thus the smoke....easy to find and fix...
08-22-2006, 03:31 PM #3
moved this to general help... i can't think of anything sarge hasn't said already
Stand Alone 5.3 starts great.....Idles rough
By Beaureed in forum Computer & TuningReplies: 3Last Post: 10-03-2016, 01:22 AM -
1996 buick roadmaster runs rough when idling and skipping
By leebooth15 in forum General HelpReplies: 5Last Post: 09-09-2014, 02:20 AM -
Help: car runs rough.
By adamz02ss in forum General HelpReplies: 4Last Post: 09-13-2011, 04:19 AM -
1 bank runs rich
By anuka in forum General HelpReplies: 6Last Post: 03-05-2009, 03:20 PM -
95 Z28 runs rough when hot
By 95maroowner in forum General HelpReplies: 5Last Post: 06-27-2007, 08:40 AM
