Results 1 to 20 of 20
04-23-2009, 01:29 PM #1Junior Member
- Apr 2009
- Oklahoma
Red- 2000 Camaro LS1
2000 Camaro misfires during acceleration
My 2000 Camaro 3.8L misfires terribly while accelerating at all RPM's. This only happens after the car has had time to warm up and continues to become more severe the longer it's driven. I've replaced fuel injectors, fuel filter, fuel pump, all plugs and plug wires. I've checked plugs and plug wires to make sure all are secure. I'm thinking it could be the coils? Need some suggestions...
04-23-2009, 04:11 PM #2Member
- Sep 2008
- kansas city mo
black- 2000 camaro ss
mine was idling fine but when you put the fuel too it would pop&crack. turned out i had a (CRACKED) spark plug. it was rather hard to see it too. before i swaped coil packs id put new plugs in her.
04-24-2009, 06:22 AM #3Junior Member
- Apr 2009
- Oklahoma
*5.7L
*2000 Camaro 5.7L. And thanks I'll be checking the plugs as soon as I get off work, that'd be great if that was the case.
04-24-2009, 06:38 AM #4
3.8 5.7 ???
04-24-2009, 06:58 AM #5
Had a similar problem on the GF's car, it was a coil pack.
02 Camaro
PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
*Old Time* 10.90@ 125mph
04-26-2009, 07:20 PM #6Junior Member
- Apr 2009
- Oklahoma
Perfect. Thanks for the help, I was hoping to hear I wasn't the only one with this problem before I ripped off the coils. Think I'll buy one coil pack and swap it out 'til I find the faulty pack.
04-26-2009, 08:59 PM #7James Bond
- Aug 2007
- Texas
so is it a 3.8 or 5.7? thats a hell of a typo
I had the same problem, turned out to be a loose plug, but our first target was TC.
how many miles on the tranny, and when was the last time you had the fluid flushed. not just just serviced, that only replaces 3-4 quarts, i mean the whole 15
04-27-2009, 06:17 AM #8Junior Member
- Apr 2009
- Oklahoma
5.7, its a hell of a typo unless I spent all day picking up parts for my 3.8L Jeep. The fluid was flushed 5 weeks ago, and the plugs look fine. 100,000 on the tranny
04-27-2009, 11:01 AM #9James Bond
- Aug 2007
- Texas
thats odd, youre supposed to flush the tranny at 100k, like you did.
I should have mentioned that sometiems the torque converter wants to lock up prematurely then it disengages quickly, making the care shutter, and feels just like a misfire, and usually under acceleration. This problem is usually mechanical, and is usually fixed by getting the tranny flushed. but it could also be the solenoid that locks up the TC. It is electrical, but its on the tranny, so i dont know if it will throw a code or not
04-27-2009, 02:22 PM #10Junior Member
- Apr 2009
- Oklahoma
its a 6-speed manual tranny...
04-27-2009, 03:32 PM #11James Bond
- Aug 2007
- Texas
04-27-2009, 04:05 PM #12Junior Member
- Apr 2009
- Oklahoma
no code. i haven't had anyone check to see which cylinder(s) (its def more than one) is/are misfiring yet
04-27-2009, 04:11 PM #13James Bond
- Aug 2007
- Texas
even without a code, they can bring up a screen that 8 circles, each representing a cylinder, with a zero beside it. i dunno how this trick would work in an M6 but in an A4 you powerbrake in reverse, tires wont spin and it will cause it to really misfire. The guy explained why that works, but i cant remember, anyway, each zero is a counter, itll show which ones are missing, and how many times. you gotta have over a certain number to throw code, but thisll show you any at all
04-27-2009, 09:23 PM #14
04-28-2009, 08:02 AM #15Junior Member
- Apr 2009
- Oklahoma
05-08-2009, 05:00 PM #16Junior Member
- May 2009
- PA
Artic white- @001 Camaro
I just posted up on another old post about something similar. Mines a 5.7 and misfires under acceration also and just feathering the gas in overdrive but it happens when it warmed up also. Is yours making a funny sound in the exuast like a missing?
05-09-2009, 06:26 PM #17Junior Member
- Apr 2009
- Oklahoma
05-09-2009, 09:08 PM #18Junior Member
- May 2009
- PA
Did you have an engine code for it or did it not show up? I'm only showing a code P1133? Also did you notice a sound coming from one side of the engine? I can hear a sound through my header and near the top of the engine on the passenger side but my driver is quiet.There was that noise. I bought a coil pack and moved it around trying each coil pack. Eventually I found one of the packs was bad and it runs great.
05-11-2009, 01:17 PM #19Junior Member
- May 2009
- PA
It ended up the spark plug wire came loose.
05-12-2009, 09:20 PM #20Junior Member
- Apr 2009
- Oklahoma
Help: Poor acceleration 2000 ls1 in 36 Chevy
By Hambone1 in forum General HelpReplies: 13Last Post: 05-13-2013, 09:38 PM -
2000 Trans Am no acceleration
By ixgotxjuice in forum Firebird / WS6Replies: 14Last Post: 10-19-2012, 11:51 AM -
Ws6 Randomly Misfires
By JeepJake in forum Firebird / WS6Replies: 24Last Post: 10-15-2012, 05:08 PM -
Still misfires but no codes
By rajiv1998 in forum General HelpReplies: 1Last Post: 04-10-2008, 01:18 PM -
Engine misfires, rough idle, minor hessitation upon acceleration
By skintox in forum Internal EngineReplies: 3Last Post: 03-02-2008, 06:23 PM
