    maryland
    98 z28
    lobe separation question
    I am thinking about doing a cam for my 98 z28. What kind of power differences should i expect between a 228/580/114 and a 228/580/112?
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    There wouldnt be much of a power difference. The difference would be where it reaches peak power. I had the f10 114 which are similar specs, but my f13 112 doesnt idle much different than it. If its an auto, get the 114, manual, 112. just my .02
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    what he said above.
    the 112 lsa will give alittle more punch down low.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    SOM BTCH
    East Palestine, OH - USA
    SOM
    2002 Chevrolet Camaro Z28
    You can run a lower LSA on an auto if you have a good tuner. Mine is a 110 LSA and I put a 113 lsa into my wifes and they both idle fine.
    Aug 2003
    Honolulu HI
    that is very true! overlap has a major role determining if the idle will be tame or not.
  1. Question: CAM worn lobe??
    By nativetalon in forum Internal Engine
    Last Post: 03-01-2011, 11:18 AM
  2. What are the Symptoms of a bad cam lobe
    By Justin93 in forum Internal Engine
    Last Post: 04-16-2009, 12:08 AM
  3. Camshaft Lobe Separation Angle Performance Test -
    Last Post: 04-01-2009, 06:56 AM
  4. Lobe Sep.
    By QUIK SILVA in forum Internal Engine
    Last Post: 01-19-2007, 04:15 PM
  5. Wife wants separation..
    By Trouble maker in forum Almost Anything Goes
    Last Post: 12-23-2006, 11:01 AM
