    Member Justin93's Avatar
    CANFIELD, OHIO
    PEWETER METALIC
    2002 CAMARO Z-28 M-6
    What are the Symptoms of a bad cam lobe
    Hey guys as you know I previously had a ticking noise after my H/C swap as well as low oil pressure. Well as it turned out the new Oil pump o ring solved the problem. My new problem is now I get an intermitant loud tick coming from the driverside head. Ive checked the pushrods and rockers and they are fine.
    Texas speed where I bought my setup from thinks that one of my new ls7 lifters that I installed with my hc setup called it quits on me premature due to previous damage being done when the oil pump oring wasnt seated correctly and caused the lifter not to pump up and a roller to go bad on the lifter.
    My question is what are the symptoms of a bad cam lobe? The car hasnt lost any power nor does the exhaust note sound different than before. Thanks for the help guys.
    I really hope this is just a lifter
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    If it is a steady tap that changes directly with RPM it may just be a lifter, it is intermittent, uneven, gets louder etc. it could be a strong sign of roller and lobe damage. Drain the oil and check for metal, if you damaged a roller or lobe you should find some evidence in the pan.
    CANFIELD, OHIO
    PEWETER METALIC
    Quote Originally Posted by DaddySS View Post
    well i pulled it in the garage yesterday and began the tear down. I is a consistant tap that goes with RPM so Im thinking I lucked out and its just a lifter. When I changed the oil the other day it did look like I had a very very small amount of metal on the the drain plug. I have everything pulled off right now. I just have to pull the heads now.
    Senior Member 01ws6er's Avatar
    The 717
    2001 Trash Can
    Yikes, best of luck to ya! Hope it didn't spin in the tray cause that's gonna be messy, but if you only had a little bit of metal in there you should be ok...
    CANFIELD, OHIO
    PEWETER METALIC
    Quote Originally Posted by 01ws6er View Post
    I hope not either cause I did the brand new ls2 trays that are supposed to prevent that from occuring!!!
    CANFIELD, OHIO
    PEWETER METALIC
    well I got the driverside head off. all looked fine except for the fact that one of the lifters seems to be stuck in the lifter bore. Please tell me Im not Screwed here!!!!!! The lifter will move about a quater of an inch but I cant seem to get it out. Advice would be greatly appreciated as I think I am now at wits end mentally and financially with this car. Next comes the gasoline and match trick out in the driveway!!!!!
    australia
    hypo yellow
    2002 vx ss
    lifter extracter
    Use a lifter extracter to get the lifter out and check the lifter bore for wear and the lifter good luck Nav.
  1. Question: CAM worn lobe??
    By nativetalon in forum Internal Engine
    Last Post: 03-01-2011, 11:18 AM
  2. Help: Cam symptoms
    By Lunatikgixxer in forum Internal Engine
    Last Post: 10-27-2010, 07:10 PM
  3. Camshaft Lobe Separation Angle Performance Test -
    Last Post: 04-01-2009, 06:56 AM
  4. Lobe Sep.
    By QUIK SILVA in forum Internal Engine
    Last Post: 01-19-2007, 04:15 PM
  5. lobe separation question
    By zman98 in forum Internal Engine
    Last Post: 06-30-2006, 07:25 AM
