Results 1 to 20 of 25
Thread: CAM worn lobe??
02-18-2011, 08:29 AM #1Junior Member
- Dec 2007
- pembroke, nc
silver & black- 2000 TA 1979 TA
CAM worn lobe??
hey what are the affects of a worn lobe on a cam? and how could i tell if that is what it is for sure? could it keep causing a lifter to fail or tick, or even a rocker to come aloose?
02-18-2011, 07:12 PM #2
u could have a misfire code..running rough..a pushrod off of rocker..Do a compression test....take the valve covers off and have a look...I had 1 lobe gone on my '79 454 & it ran like poop...
02-19-2011, 02:53 AM #3Junior Member
- Feb 2011
- australia
White- 72 HQ Holden
I'd wip the valve covers off and check the valve lash if you think its worn a lobe off, why do you suspect this problem? Its not usually the first point of call.
02-20-2011, 12:30 PM #4Junior Member
- Dec 2007
- pembroke, nc
i had a tick. kinda drove it like that for a year because there were no performance problems i could tell since it was ticking wen i bought it. then recently i changed the rockers the arms and also intake. and it still ticks!. and It sounds like something is going to come aloose now.
02-20-2011, 03:53 PM #5Junior Member
- Feb 2011
- australia
White- 72 HQ Holden
I would think you would have metal contamination in the oil if it was slowly wearing a lobe away, do you do your own oil changes? If so check both the oil and oil filter, i cut mine open and fan out the media to see exactly whats going on, or you could send a sample out for an oil analysis, that will tell you for sure what is in the oil, what type of metal and where in the engine its coming from.
02-20-2011, 04:05 PM #6
A small exhaust leak will often times sound like a "tick".
02-20-2011, 04:16 PM #7Junior Member
- Feb 2011
- australia
White- 72 HQ Holden
Reading your first post again, a worn lobe obviously increases the clearance at the rocker tip and valve top, this could very well be the tick and if left unchecked will flog out the pushrod seat in the rocker, could wear the top of the valve with the constant jackhammering from increased clearance and i have had a pushrod come adrift from the rocker and smacked up against the inside of the valve cover making a horrible noise, luckily i shut it down quick,that engine was a straight six but when i had a rocker break on my 400SBC the rotating cam lobe flicked the lifter out of its bore, this could have been real bad if that lifter had made it down one of the drain back holes and 'interfered' with the crank. You won't always notice 1 cylinder down in a V8 caus the others compensate, i only knew something was up when i came to a stop and the idle was a bit fluffy, a 4cylinder with a dropped cylinder shows up much more dramatic.
02-20-2011, 04:44 PM #8
Piston slap usually sounds kinda like a tick
A lifter going out sounds like a tick
Like PAJeff said, exhaust leak sounds like tick
Valve train can sound like a tick (Sewing machine)
Worn cam lopes are very uncommon in the LS1 motors. They use roller lifters which don't wear on the cam as much as older motors. I would not suspect that first. Rockers are known for losing the needle bearings, thats probably not the noise but I would suspect almost everything before a worn cam lope. Just my .02
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
02-20-2011, 06:52 PM #9
I actually found evidence of worn lobes I have 2 bad 1s on my original cam that has 130000k on it ill try n post pics up.
02-20-2011, 08:11 PM #10
02-20-2011, 08:27 PM #11
I'm being 100%honest to lobes are noticably ruined....ever since I bought the car it had a noticable skip in the power band,when I get home and on my comp ill take a pic of the lobes,maybe there not ruined but they are deff worn looking compared to the rest.
02-20-2011, 08:38 PM #12
02-21-2011, 09:29 AM #13
Does it have aftermarket springs, rockers, or lifters in it? Your post said that you changed the rockers, but not with what.
02-22-2011, 02:07 PM #14Junior Member
- Dec 2007
- pembroke, nc
yes all aftermarket new top end except for the valves and cam and heads. Comp Cams ultra gold rockers
02-22-2011, 02:11 PM #15
02-22-2011, 02:13 PM #16Junior Member
- Dec 2007
- pembroke, nc
i think I'm going to have to tear it down soon to find out.
02-22-2011, 02:37 PM #17
Got the pictures to show you all the cam,but my computer isn't working right now,ill sure start a thread about it when its up n running to see what all of you think could cause this.
02-22-2011, 03:28 PM #18
02-23-2011, 12:43 PM #19
I have a regrind I got off Ebay laying in the garage for my ls1...after running it for less than a year it had VERY bad grooves worn into it
02-24-2011, 07:25 PM #20
Worn Out Upholsetry
By navyLS1 in forum Firebird / WS6Replies: 4Last Post: 01-31-2010, 07:40 PM -
What are the Symptoms of a bad cam lobe
By Justin93 in forum Internal EngineReplies: 6Last Post: 04-16-2009, 01:08 AM -
Camshaft Lobe Separation Angle Performance Test -
By Ed Blown Vert in forum Camaro / SSReplies: 5Last Post: 04-01-2009, 07:56 AM -
Lobe Sep.
By QUIK SILVA in forum Internal EngineReplies: 21Last Post: 01-19-2007, 05:15 PM -
lobe separation question
By zman98 in forum Internal EngineReplies: 4Last Post: 06-30-2006, 08:25 AM
