    so. Cal
    MidnightBlue
    2001 TransAm
    oil drain plug size
    what size is it? i am having issues. think i need some sleep, but i can't get the damn thing off. . . . .thanks
    Tennessee
    1999 Pontiac Trans Am
    If you mean the wrench size, 15mm. Tighten to 225 inch lbs.
    Senior Member
    Jacksonville, FL
    Yep, 15 MM. Oil change places like to overtighten it; filter too.
    May 2018
    1999 30th Anniv Trans AM
    Originally thought that this topic would cover drain plug thread size. I believe I have since found the right drain plug on Jegs as Thread Size: M12-1.75. Is that correct?
    Also, it appears they also sell a rubber washer/gasket for the drain plug. Does the stock LS1 drain plug have a replaceable rubber washer/gasket on it?
    Mine is seeping and I'd rather replace a washer instead of the whole drain plug if in fact it's replaceable. Thanks for any help.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    yes it is 12mm x 1.75. just buy the whole bolt. i think the gasket is integrated.
    Member sjgreen6's Avatar
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    2002 Trans Am WS6 Conv
    Current GM Part number is 11562588. Has the integrated gasket.
  1. Oil drain plug tool
    By tatertot91 in forum Tools
    Last Post: 02-18-2012, 08:07 PM
  2. Question: drain plug
    By 2000dreambird in forum Manual Transmission
    Last Post: 04-15-2010, 11:59 AM
  3. Help: Junk on my Drain Plug
    By third_shift|studios in forum Internal Engine
    Last Post: 09-18-2009, 10:35 AM
  4. Smoke from the oil drain plug??
    By Neil in forum General Help
    Last Post: 06-08-2009, 02:26 PM
  5. Transmission pan w/ drain plug *******
    By LETHALxLS1 in forum Automatic Transmission
    Last Post: 11-25-2006, 12:53 PM
