Thread: drain plug
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    drain plug
    does anyone know what size and thread size the drain plug is on the t56 i want to put a fluid sensor there so i can read tranny temp
    phoenix
    04 2500 4x4 crew cab
    should have asked two days ago, i had mine out on fri.... wouldnt it be easier to put in the fill plug, though? it would be higher, and you wouldnt have to drop tranny fluid to service/install it.
    Try roasting your crow. It'll be easier to get down.
    I like grilling mine with a nice brown sugar based rub
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    Quote Originally Posted by az gt eater View Post
    Ya but it's not going to sit in the fluid at the fill point would it?
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    na the fill hole wouldn't' provide sufficient soaking / temp readings
    why do you want to know the fluid temp? If you have a proper fluid level your temps should be fine, what can you do about it anyways if it reads too hot?
    Dec 2004
    SS: NBM, tan top
    you're not just trying to fill holes in an aftermarket pillar cluster are you? haha
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    i have a set of interceptor gauges on the way and they run off the OBDII they will read tranny temp but i need to put a sensor in it if i had a A4 it would already have the sensor.i just like my gadgets and i want to get the most out of it that i can.
    phoenix
    Ummmmm,good point.
    Quote Originally Posted by 2000dreambird View Post
  1. oil drain plug size
    By JoeRiceKillr in forum General Help
    Last Post: 05-07-2018, 02:33 PM
  2. oil drain plug won't back out
    By 98TransAmWs-6 in forum General Help
    Last Post: 10-18-2011, 05:01 PM
  3. Help: Junk on my Drain Plug
    By third_shift|studios in forum Internal Engine
    Last Post: 09-18-2009, 10:35 AM
  4. Question: Oil Drain Plug location?
    By iceman504 in forum General Help
    Last Post: 03-21-2008, 04:23 PM
  5. Transmission pan w/ drain plug *******
    By LETHALxLS1 in forum Automatic Transmission
    Last Post: 11-25-2006, 12:53 PM
