Results 1 to 20 of 80
Thread: oil drain plug won't back out
04-11-2011, 08:45 AM #1Senior Member
- Apr 2010
- Alabama
I went to change my oil the other day and I got the drain plug about 75% out when it wouldn't come out any more because the header was in the way. Is there any way to get it out without having to take my header off? It's weird I have changed my oil with headers and it wasn't in the way but now it is for some reason. Any help would be appreciated.
04-11-2011, 08:51 AM #2its short but its skinny.
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
perhaps take either side motor mount loose and jack up the engine...see if it makes clearance
04-11-2011, 09:40 AM #3
how long is the damn bolt!?
it shouldnt even come close to any style header!!!
04-11-2011, 10:14 AM #4
sounds like you might have the wrong size bolt in there. i don't think losseing the motor mount is going to help with clearance because the header is attached to the motor. The only thing will be to remove the header or band out the area where the bolt is coming out to create some clearance.
but i have to agree that the bolt is too long.
04-11-2011, 10:30 AM #5
04-11-2011, 10:48 AM #6
I won't think so because the header and the motor are one piece and the mount holds the motor. if the header was not attached to the engine i will say yes to that. I mean that what makes sense to me. are your mounts really bad?
Im really interested to find out since you had the headers before. does the header looks like is hitting somewhere?
Can you post a pic?
04-11-2011, 10:49 AM #7
Weird, that bolt isn't that long. Does it look like one side is sagging more than the other?
04-11-2011, 11:18 AM #8O U 8 1 2
- Nov 1999
- over here...
trans drain plug maybe??? that definitly isn't the oil plug...
04-11-2011, 11:50 AM #9
04-11-2011, 12:02 PM #10
04-11-2011, 12:34 PM #11Spaz is My Mentor
Quick way to answer before or after the bell housing?
Even if it is the trans plug it's not that close to the ORY or LT's at least mine in my T56 isn't. If I'm droppin the tranny I pull it and let it start draining while I'm working on other stuff.
04-11-2011, 01:07 PM #12its short but its skinny.
- Oct 2009
pewter- 99 trans am
damn im dumb lol....thinkin the mount would allow clearance....didnt even think lol
04-11-2011, 01:09 PM #13
04-11-2011, 01:11 PM #14
04-11-2011, 01:31 PM #15
04-11-2011, 02:45 PM #16
Did you hit the crap out of your exhaust or something?
04-11-2011, 04:05 PM #17
Subscribed...
04-11-2011, 07:24 PM #18
04-12-2011, 04:21 AM #19
04-12-2011, 04:29 AM #20O U 8 1 2
- Nov 1999
- over here...
skip class and post the pictures...
oil drain plug size
By JoeRiceKillr in forum General HelpReplies: 5Last Post: 05-07-2018, 02:33 PM -
Oil drain plug tool
By tatertot91 in forum ToolsReplies: 0Last Post: 02-18-2012, 08:07 PM -
Question: drain plug
By 2000dreambird in forum Manual TransmissionReplies: 6Last Post: 04-15-2010, 11:59 AM -
torque for oil drain plug?
By grandkodiak in forum LT1Replies: 17Last Post: 07-02-2009, 03:00 PM -
Question: Oil Drain Plug location?
By iceman504 in forum General HelpReplies: 12Last Post: 03-21-2008, 04:23 PM
