Results 1 to 18 of 18
Thread: torque for oil drain plug?
07-01-2009, 11:44 AM #1
gunna do a an oil change cant find my paper... i know the filter is 15ftlbs but what is the drain plug spec? all i could find is that its 15mm...nothin about torque
07-01-2009, 01:04 PM #2
I have never, never torqued a drain plug in my life. Or a oil filter. I have done 1000's of oil changes on Cat equipment and never even heard of a spec.
Drain plug - tighten untill snug.... then just a 'little' extra. Drain plugs require very little. It just needs to be tight. No rocket science.
Oil filters. Cat actually has directions. No TQ number. Turn into snug, then 3/4 more turn. Thats it.
Basically, just tighten them. German torque.
Goodntight
07-01-2009, 01:08 PM #3
err appreciate the info but anyone have an answer to the question?
07-01-2009, 01:36 PM #4
07-01-2009, 01:37 PM #5
and these....
Accelerator Control Cable Bracket Bolts............................................. .....89 lb in
Air Conditioning Compressor Bolts............................................. .............37 lb ft
Air Conditioning Compressor Bracket Bolts............................................. .37 lb ft
Air Conditioning Idler Pulley Bolt.............................................. ...............37 lb ft
Air Conditioning Tensioner Bolt.............................................. .................18 lb ft
Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts........................15 lb ft
Camshaft Retainer Bolts............................................. ............................18 lb ft
Camshaft Sensor Bolt.............................................. ...............................18 lb ft
Camshaft Sprocket Bolts............................................. ...........................26 lb ft
Catalytic Converter Nut............................................... ...........................18 lb ft
Connecting Rod Bolts - First Design (First Pass)........................................15 lb ft
Connecting Rod Bolts - First Design (Final Pass)........................................60 degrees
Connecting Rod Bolts - Second Design (First Pass)....................................15 lb ft
Connecting Rod Bolts - Second Design (Final Pass)...................................75 degrees
Coolant Temperature Gauge Sensor............................................ ............15 lb ft
Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed)........240 lb ft
Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as described in the First and Final Passes)........................................... .........37 lb ft
Crankshaft Balancer Bolt (Final Pass)............................................. ..........140 degrees
Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence).............15 lb ft
Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence).............80 degrees
Crankshaft Bearing Cap Side Bolts............................................. ..............18 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence)...........15 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence)...........53 degrees
Crankshaft Oil Deflector Nuts.............................................. .....................18 lb ft
Crankshaft Position Sensor Bolt.............................................. ..................18 lb ft
~~~~~~~~~~Cylinder Heads~~~~~~~~~~
Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)...........................22 lb ft
Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)......................90 degrees
Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)............................................. ...............................90 degrees
Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)......................................... .................................................5 0 degrees
Cylinder Head Bolts (M8 Inner Bolts in Sequence).....................................22 lb ft
Cylinder Head Coolant Plug.............................................. .......................15 lb ft
Cylinder Head Core Hole Plug.............................................. ....................15 lb ft
Drive Belt Idler Pulley Bolt.............................................. .........................37 lb ft
Drive Belt Tensioner Bolts............................................. ...........................37 lb ft
Engine Block Coolant Drain Plugs............................................. .................44 lb ft
Engine Block Heater............................................ .....................................30 lb ft
Engine Block Oil Gallery Plugs............................................. ......................44 lb ft
Engine Coolant Air Bleed Pipe Bolts and Studs............................................1 06 lb in
Engine Crossmember Bolts (Large)........................................... .................107 lb ft
Engine Crossmember Bolts (Small)........................................... .................92 lb ft
Engine Flywheel Bolts (First Pass)............................................. ..................15 lb ft
Engine Flywheel Bolts (Second Pass)............................................. .............37 lb ft
Engine Flywheel Bolts (Final Pass)............................................. .................74 lb ft
Engine Flywheel-to-Torque Converter Bolts............................................. ....44 lb ft
Engine Front Cover Bolts............................................. ..............................18 lb ft
Engine Mount Heat Shield Nuts.............................................. .....................89 lb in
Engine Mount Stud-to-Engine Block............................................. ................37 lb ft
Engine Mount Through Bolts............................................. ..........................70 lb ft
Engine Mount Through Bolt Nuts.............................................. ...................59 lb ft
Engine Mount-to-Engine Block Bolts............................................. ...............37 lb ft
Engine Rear Cover Bolts............................................. ..............................18 lb ft
Engine Service Lift Bracket M10 Bolts............................................. ............37 lb ft
Engine Service Lift Bracket M8 Bolt.............................................. ...............18 lb ft
Engine Valley Cover Bolts............................................. .............................18 lb ft
Engine Wire Harness Clip Bolt.............................................. ......................37 lb ft
Engine Wire Harness Ground Strap Bolt.............................................. ........37 lb ft
Exhaust Gas Recirculation (EGR) Valve Bolts (First Pass)..............................89 lb in
EGR Valve Bolts (Final Pass)............................................. .........................22 lb ft
EGR Valve Pipe-to-Cylinder Head Bolts............................................. ..........37 lb ft
EGR Valve Pipe-to-Exhaust Manifold Bolts............................................. ......22 lb ft
EGR Valve Pipe-to-Intake Manifold Bolt.............................................. .........89 lb in
Exhaust Manifold Bolts (First Pass)............................................. .................11 lb ft
Exhaust Manifold Bolts (Final Pass)............................................. ................18 lb ft
Exhaust Manifold Heat Shield Bolts............................................. .................80 lb in
Exhaust Manifold Pipe Nuts.............................................. ...........................26 lb ft
Front Shock-to-Engine Crossmember Bolts............................................. .....48 lb ft
Fuel Injection Fuel Rail Bolts............................................. ..........................89 lb in
Generator Bracket Bolts............................................. ...............................37 lb ft
Generator Rear Bracket-to-Engine Block Bolt.............................................. .18 lb ft
Generator Rear Bracket-to-Generator Bolt.............................................. .....18 lb ft
Ground Strap Bolt (at Rear of Cylinder Head)............................................. ..37 lb ft
Ignition Coil-to-Bracket Bolts............................................. .........................106 lb in
Ignition Coil Bracket-to-Valve Rocker Arm Cover Bolts.................................106 lb in
Intake Manifold Bolts (First Pass in Sequence)......................................... .....44 lb in
Intake Manifold Bolts (Final Pass in Sequence)......................................... ....89 lb in
Knock Sensors........................................... ...............................................15 lb ft
Oil Filter............................................ .................................................2 2 lb ft
Oil Filter Fitting........................................... ...............................................40 lb ft
Oil Level Indicator Tube Bolt.............................................. ........................18 lb ft
Oil Level Sensor............................................ ...........................................115 lb in
Oil Pan Baffle Bolts............................................. ......................................106 lb in
Oil Pan Closeout Cover Bolt (Left Side)............................................. ..........106 lb in
Oil Pan Closeout Cover Bolt (Right Side)............................................. ........106 lb in
Oil Pan Cover Bolts............................................. ......................................106 lb in
Oil Pan Drain Plug.............................................. .......................................18 lb ft
07-01-2009, 01:38 PM #6
Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil Pan-to-Front Cover)...........18 lb ft
Oil Pan M6 Bolts (Oil Pan-to-Rear Cover)............................................ ........106 lb in
Oil Pressure Sensor............................................ ......................................15 lb ft
Oil Pump-to-Engine Block Bolts............................................. .....................18 lb ft
Oil Pump Cover Bolts............................................. ...................................106 lb in
Oil Pump Relief Valve Plug.............................................. ...........................106 lb in
Oil Pump Screen Nuts.............................................. ..................................18 lb ft
Oil Pump Screen-to-Oil Pump Bolt.............................................. .................106 lb in
Oxygen Sensor............................................ .............................................31 lb ft
Positive Crankcase Ventilation (PCV) System Strap Nut (at Right Front Vapor Vent Pipe Stud)......106 lb in
Power Steering Pump Bolts............................................. ...........................18 lb ft
Power Steering Pump Bracket Bolts............................................. ...............18 lb ft
Spark Plugs (Cylinder Heads-New).............................................. ...............15 lb ft
Spark Plugs (all Subsequent Installations).................................... ...............11 lb ft
Throttle Body Bolts............................................. .......................................106 lb in
Transmission Housing Bolt.............................................. ...........................37 lb ft
Valve Lifter Guide Bolts............................................. ................................106 lb in
Valve Rocker Arm Bolts............................................. ................................22 lb ft
Valve Rocker Arm Cover Bolts............................................. ......................106 lb in
Water Inlet Housing Bolts............................................. .............................11 lb ft
Water Pump Bolts (First Pass)............................................. .......................11 lb ft
Water Pump Bolts (Final Pass)............................................. .......................22 lb ft
Water Pump Cover Bolts............................................. ...............................11 lb ft
07-01-2009, 01:39 PM #7
err , ok?
Edit, I should mention, these are for a LS1. My bad, Im sorry. If you go to those two numbers, Im sure you will be fine.
But, I also had quite a few google searchs come up with.... I shit you not...
Goodentite.Last edited by Hi-Po; 07-01-2009 at 01:41 PM.
07-01-2009, 01:54 PM #8
07-01-2009, 02:23 PM #9
This thread alone started me thinking about how many drain plugs I have tightened in my last 4 years of living. Never knew anyone ever wanted an answer to such a TQ spec question really. I bet my bottom dollar I was gonna spend on my TA that I have "TQ'd" over a 1500 drain plugs in the last 3-4 years, at least!! Thats the lowest ballpark figure I could come up with. And never even think about TQ'ing them.
Seriously, just tighten them. Your putting too much thought into it.
07-01-2009, 05:45 PM #10
I work in the automotive feild. TQ for the drain plug is 18 depending on the motor size. Believe it or not v6 is TQ higher. One of the biggest claims at oil change services is over tourquing the drain plug. The worst that can happen it a stripped plug or oil pan. The oil filter states on the filter itself how to TQ it.
07-01-2009, 06:06 PM #11
after finding 4 different suggestions online i found it in a lt1 rebuild book pdf copy... thanks all for the input.
yea im anal... but the point is to know for sure... to say ls1 is close enough or whatever is to guestimate... might as well not use it at all at that rate.
aircraft spec people... think engineer not mechanic.
07-01-2009, 06:52 PM #12
I agree Hi-Po, just snug and then a bit more...never torqued down an oil drain plug or filter...
Ha ha, i can't imagine how much time i'd waste torquing down every bolt. The only bolts I've torqued and checked were my converter bolts.
07-01-2009, 07:26 PM #13
anything worth doing is worth doing to torque spec. lol
my torque wrench actually is the only tool I have that ratchets anywho... might as well use it. the extra second to set it... well, i have plenty time to spare.
07-01-2009, 09:35 PM #14
If you overtighten your drain plug, your car wont plunge out of the sky and kill 150 people. Being an aviation mechanic is apples to oranges with an automotive tech. Besides, it's just a feel thing, if you cant feel it, then use the torque wrench, no problem with that. Those of us that have done this for a living just get the feel for certain things that arent that sensitive to a specific specification. Then there are bolts (mostly on engines and other driveline parts) that it most certainly is worth the time to torque to a spec and evenly across many bolts.
07-01-2009, 09:51 PM #15
I fix what the engineers mess up. If you work on cars/trucks you are a engineer. Have you work on a 6.0 powerstroke. Some design are plum ass retarded.
07-02-2009, 05:37 AM #16
07-02-2009, 10:06 AM #17
07-02-2009, 03:00 PM #18
oil drain plug size
By JoeRiceKillr in forum General HelpReplies: 5Last Post: 05-07-2018, 02:33 PM -
Oil drain plug tool
By tatertot91 in forum ToolsReplies: 0Last Post: 02-18-2012, 08:07 PM -
Question: drain plug
By 2000dreambird in forum Manual TransmissionReplies: 6Last Post: 04-15-2010, 11:59 AM -
Smoke from the oil drain plug??
By Neil in forum General HelpReplies: 6Last Post: 06-08-2009, 02:26 PM -
Question: Oil Drain Plug location?
By iceman504 in forum General HelpReplies: 12Last Post: 03-21-2008, 04:23 PM
A quick google search came up with some numbers.
