Thread: Smoke from the oil drain plug??
06-08-2009, 11:12 AM #1Member
- Woodbridge, VA
Navy Blue Metalic- 1999 Z28 Convertible
My daughtor's car (2001 Plymouth Neon) has a low oil lpressure light at low RPMs. I decided to add a heavier weight oil this weekend to see if that would make it last at least a little longer. When I was draining the oil, I noticed that white smoke was coming out of the drain plug hole. The engine was cold - it hadn't been started in a day, and all I did was start it and drive it up on ramps. Any ideas on what would cause that?
06-08-2009, 11:14 AM #2
06-08-2009, 01:25 PM #3
06-08-2009, 01:29 PM #4Member
- Woodbridge, VA
Is that caused by bad rings? It's sounding like this engine needs a rebuild.
06-08-2009, 01:38 PM #5
I don't think it would have smoke coming out a day after it had been shut off. Any blowby should have dissipated in that time frame. A quick compression check and cylinder leak down will let you know what's going on.
06-08-2009, 02:20 PM #6Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Ring packs are probably frozen allowing blow by.
Plugged PCV and/or carbon/varnish build up around the ring packs are the two normal suspects.
I would AutoRX it and make damn sure her PCV is fully operational.
http://www.auto-rx.com/
Check the PCV and make sure it is fully operational. Crankcase pressure must be relieved somewhere or the rings will not seal properly.Last edited by Sarge; 06-08-2009 at 02:24 PM.
06-08-2009, 02:26 PM #7Grand Imperial Wizard
Some light reading on PCV/Crankcase pressure et al....
http://www.ls1.com/forums/showthread.php?t=81389
Oil drain plug tool
By tatertot91 in forum ToolsReplies: 0Last Post: 02-18-2012, 08:07 PM -
Question: drain plug
By 2000dreambird in forum Manual TransmissionReplies: 6Last Post: 04-15-2010, 11:59 AM -
Help: Junk on my Drain Plug
By third_shift|studios in forum Internal EngineReplies: 27Last Post: 09-18-2009, 10:35 AM -
torque for oil drain plug?
By grandkodiak in forum LT1Replies: 17Last Post: 07-02-2009, 03:00 PM -
Question: Oil Drain Plug location?
By iceman504 in forum General HelpReplies: 12Last Post: 03-21-2008, 04:23 PM
