Results 1 to 3 of 3
    USA
    BLACK
    Z/28 LS1
    Transmission pan w/ drain plug *******
    I recently bought a 98 z-28 with an automatic transmission. I am going to change the transmission filter and fluid and want to replace the pan with a new pan that has a drain plug. Also,is it a good idea to get a pan that holds more transmission fluid than the stock pan? Can anyone tell me where to buy one and possibly the part#. Would I come out better buying the kit where you can add your own drain plug to the stock pan? Thanks for your help on this guys.--------deadbydawn421 (mike)
    Cedar Rpaids,IA
    1998 Camaro SS
    re
    Derale Transmission Pans. I have one and have had no problems with it. It has a drain plug and holds a little more fluid then normal. The cooling tubes seem to be a good idea and most likly work. Summit Racing has them part# DER-14104.
    What more fluid does is it gives the transmission more fluid to remove heat from the tranny, it also does not allow the tranny to heat up as quickly since it takes more energy to heat a larger amount of fluid. I'd also install a transmission cooler, it will greatly decrease the tranny's temp and help prolong its life.
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
    Moving to drivetrain forum.
    Painted manta stripe
  1. Oil drain plug tool
    By tatertot91 in forum Tools
    Last Post: 02-18-2012, 08:07 PM
  2. Question: drain plug
    By 2000dreambird in forum Manual Transmission
    Last Post: 04-15-2010, 11:59 AM
  3. Help: Junk on my Drain Plug
    By third_shift|studios in forum Internal Engine
    Last Post: 09-18-2009, 10:35 AM
  4. Smoke from the oil drain plug??
    By Neil in forum General Help
    Last Post: 06-08-2009, 02:26 PM
  5. Question: Oil Drain Plug location?
    By iceman504 in forum General Help
    Last Post: 03-21-2008, 04:23 PM
