Results 1 to 3 of 3
Thread: Ls1 map sensor brake vacuum line
05-30-2020, 11:36 AM #1
- May 2020
- vancouver,wa
Hey guys, I've swapped a ls1 into my 73 camaro and have a question about the map sensor vacuum lines. On my 73 camaro I have a manual brake setup with no booster so what can I do about the vacuum line that goes from map sensor to the brake booster? I have heard you need it hooked up for the engine to run right or can i block it like the other line on the map sensor?
I have done some searching and couldn't find anything. Appreciate the help.
05-31-2020, 03:25 AM #2
If memory serves, the line from the MAP plumbs into a "T" of "Y" fitting located near the back passenger side of the engine. That line runs up to the throttle body (It's been a while since I have had that apart). You can simply forget about the run to the booster and plug the line off after the MAP connection or custom plumb it.
05-31-2020, 12:25 PM #3
- May 2020
- vancouver,wa
thanks for the response
Help: 2002 ls1 ac vacuum line
By johnfin in forum Camaro / SSReplies: 1Last Post: 03-11-2018, 03:59 AM -
Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
By 1batt4u in forum General HelpReplies: 5Last Post: 11-13-2014, 05:42 PM -
Vacuum Line Question
By jfl330 in forum External EngineReplies: 15Last Post: 06-29-2012, 01:39 PM -
Vacuum Line Connections...
By Rick@Metco in forum General HelpReplies: 3Last Post: 10-12-2010, 03:15 PM -
Question: 99 3.8 V6 MAP vacuum line?
By SSTODD in forum V6Replies: 1Last Post: 02-20-2010, 08:40 AM
